Question about Dell OptiPlex GX260 PC Desktop
There was a flutuation in power supply and it refuse to boot
There was a flutuation in power supply and my dell optiplex Gx260 refuse to complete booting, it will always stop asking me to start computer normally or in safe mode, when i select either options, it restarts and stop at the same point, am confuse and i need to work with it urgently, i must confess it has been wonderful using it, just this power problem this model usually have, pls i so wish to be replied through my e-mail as well for ease...johnier4life@yahoo.com
  • Graeme van Malsen
    Graeme van Malsen May 11, 2010
    I would like to assist you in resolving your problem as soon as possible, but I need to know what operating system you use and if you have the original CD of your operating system.
    Best wishes,
    Graemevm
  • Bruce Volkers
    Bruce Volkers May 11, 2010
    Ok, I understand it won't boot into safe mode graphical but can you get it to do safe mode command prompt only? If so there is a powerful command you can type at the prompt that might fix it. Let me know.
    Sergeant:
    Champion:
  • 245 Answers
Hi it looks to me ur motherboard had a shock from this power fluctuation u have.....
it may solve the problem itself if u have patient..if not i would say uninstall and reinstall ur cumputer with the version u have or go to VISTA ALSO WOULD RECOMMENDED TO GET A POWER SURCHARGE WHO WILL PROTECT UR COMPUTER
Posted on May 22, 2009
How to Boot from USB in DELL Optiplex GX260
Hi Junaid
Can you please supply a little more info so that we can try assist you.
With the little info we have to work on maybe I can suggest you need to make a bootable operating system to use in your device connected to your USB port to boot the machine.
Hope this helps
Kind regards
Aug 19, 2014 | Dell OptiPlex GX260 PC Desktop
Hello! I have a dell optiplex gx260 pc i am having a problem that my pc does not boot it does not show any screen nor any beep its backlight light orders are A OFF B Yellow C OFF D OFF i have...
If the power LED is flashing amber, there may be an issue with the power supply, if it is solid amber then the motherboard itself (or if it has an expansion card in a slot, maybe the card)
Jun 08, 2011 | Dell OptiPlex GX260 PC Desktop
Optiplex gx820 can i connect 300 watt power supply
You listed GX820 and GX260.
I am assuming you meant the GX260.
There are three varieties of the Gx260.
1) The SFF (Small Form Factor) power supplies can be replaced, but I know of no upgrades for these.
2) For the SDT (Small Desk Top), you can get up to a 270 (best I have seen).
Example of where to get one.
http://www.atxpowersupplies.com/180-watt-dell-power-supply-1n405.php?psu=1N405-GX260SmallDesktop
For the Mini Tower, here is an example of a 400W replacement. There may be others for this model.
http://www.cputopia.com/dell-400w-dell-optiplex-gx260.html
I have a GX280 Mini Tower and recently upgraded my PSU to one very similar to the one above.
Feb 21, 2011 | Dell OptiPlex GX260 PC Desktop
Best processor for a dell optiplex gx260
whats the current processor installed? it can possible handle P4 procs up to 2.0 to 2.4Ghz..
Feb 14, 2010 | Dell OptiPlex GX260 PC Desktop
Will a dell gx280 motherboard fit into a gx260 (dell) case?
If it is a slim gx260 case, it might not. If it is the wide case, it will, but the two motherboards have different power supplies. You will need to use a gx280 power supply to power it on. However, you can use a gx270 motherboard in a gx260 case without changing the power supply.
Hope this helps!
Oct 26, 2009 | Dell OptiPlex GX260 PC Desktop
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
Fluation in power supply resulted incomplete booting
hi there,
if the safe mode does not work,it is better you to reinstall your windows again,some file have been corrupted already,the only way
is to insert your windows cd installer and have your new windows install again if you want go to recovery system wizard try to recover your start up windows.have a nice day!
May 22, 2009 | Dell OptiPlex GX260 PC Desktop
Optiplex GX260 won't boot
I had the same issue and accidentally discovered a temporary solution. Unplug the power from the back of the machine, open the case and unplug the ATX power connection from the motherboard. With the ATX cable unplugged, plug the power cord back in. When you try to turn the computer back on the power light should turn orange and fans should be spinning, with it powered on plug the ATX connector back in. That should turn the computer off. Turn it back on and it should boot fine. You can even shutdown and restart, but when the power is unplugged you will have to go thru the same process to get it back up. This sounds crazy but it worked on mine. Good Luck!
Nov 01, 2007 | Dell OptiPlex GX260 PC Desktop
Dell GX260
can you be more specific when describing the computer 'struggling to restart'? Does it beep? Does it take several attempts to restart?
Aug 09, 2006 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
