Question about Barco CLM-HD8 Projector
Reset lamp remote - Barco CLM-HD8 Projector
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
Be sure the power cord is plugged into a properly grounded wall outlet.
Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the
PIP or SPLIT button on the remote control at same time for more than 5 seconds.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 | Televison & Video
Reset lamp timer lg projector model BX-401C
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | Office Equipment & Supplies
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
E44W46LCD Lamp Timer Reset
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
Jan 09, 2009 | Zenith E44W46LCD 44" Rear Projection...
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Barco CLM-HD8 Projector Logo
16 people viewed this question
Top Barco Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Barco Office Equipment and Supply Expert? Answer questions, earn points and help others
