Question about Refrigerators
Amana complaints defroster doesnt work. ice build up in freezer then temp rises in refrigerator
  • Refrigerators Master
  • 9,639 Answers
The defrost timer could be out or the defrost heater could be bad
Posted on Jan 17, 2014
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 72 Answers
    SOURCE: Our freezer is not cold, food is defrosting, ice
    Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
    Posted on Jun 20, 2009
    EllaWatson25
    • 725 Answers
    SOURCE: Amana ABB2224DEW bottom freezer defrost problem
    You have a defrost problem. You will need to replace your defrost system. Before you put the parts on, you need to completely thaw out your unit. You can do this by leaving it open all day or night or by placing a fan close to it with the door open. We have parts, so please give us a call and we'll be sure to ge the right parts out to you right away. We look forward to hearing back from you.
    Posted on Sep 16, 2009
    Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
    Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
    If you need any further assistacne please feel free to comment me.
    Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
    Amana Model# ARS2365AC The freezer is not keeping the food frozen and the refrigerator is not as cold as it use to be. Both control dials are on 7 the maximum it can go. Thank you for all your...
    if the rear wall inside the freezer has ice build-up on it then the defrost isnt working,remove this panel and check evaporator coil if its iced up the evaporator fan cant blow the cold air thru this coil,defrost it with a hand held hair dryer,then check the heating element located below the evaporator coil for continuity then check the round defrost thermostat on the top of the evaporator coil,note,this part needs to be tested below 32degrees to test good above that temp it will show open or bad
    May 29, 2011 | Amana 22.6 cu. ft. Side-By-Side...
    My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
    ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
    Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
    Water dripping inside of freezer, forms ice-cicles, water doesn't dispense and temp. rises on both freezer and refrigerator.
    Check rear inside wall of freezer for frost build up, this prob is an indication that you have a defrost problem, like a bad defrost heater or defrost control.
    Sep 28, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Freezer not freezing properly, ice on back wall
    Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
    Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
    May 29, 2009 | Amana ABB1927DE Bottom Freezer...
    Amana ARB2217CSR freezer not working right
    You have defrost control parts failure.
    Either defrost timer, defrost thermostat or defrost heater.
    Feb 21, 2009 | Amana ARB2217CSR Bottom Freezer...
    Jan 21, 2009 | Amana Refrigerators
    Freezer is not making ice and the temp seems to be dropping.
    You may have a defrost issue,Please check and see if it has an accumulation of ice build up in the back and post back.
    Jan 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Frost accumulation on ice maker
    Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
    Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
    Refrigerators Logo
    32 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
