Question about Mitsubishi WS-55511 55" Rear Projection Television
WS55511Mitsubishi TV convergance problem
I was watching tv and it just developed a blue 3D shadow. When I tried to adjust convergance it was wavy and way off and would not adjust. Problem remained after unit cooled off and was turned back on. What is the fix? Is there a chip or resistor that has gone bad? Where can I find current schematic's that show componet lay out?
Thanks
  • Mitsubishi Master
  • 3,459 Answers
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
645fba6.jpgWS55511Mitsubishi TV convergance problem - 0dcec37.jpgmi
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips areWS55511Mitsubishi TV convergance problem - 0667c5f.pngould be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on May 22, 2009
We need to figure out how to get it off of the 3d setting we just recieved this tv from a friend of ours and we are trying to figure out how to view it without the 3d our tv is a mitsubishi big screen...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 29, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Hi, I'm having the same type of problem with my tv. It has the 3d look to the screen but it also has a large wavy red line through the top of the screen. Would this also be the result of the convergence...
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 28, 2011 | Hitachi 51F500 51" Rear Projection...
Bowed red green lines at top screen. picture looks like it in 3d.
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
The red in the picture is shadowing the rest of the picture giving it a 3d effect
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
I turned my tv on this morning and the colors were all out of wack. the tv was producing an image similer to what an old 3d movie with the red and blue images. i tried reseting the tv to factory default...
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
Picture is coming up as 3D
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 21, 2011 | Mitsubishi VS-55601 55" Rear Projection...
When i turn it on, it gets a blue looking shadow color and the letters and numbers look like you're watching a 3D picture without glasses
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Hitachi 60DX10B 60" Rear Projection...
I heard a pop and then the color was like looking at a 3d tv without the glasses
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 06, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Showing colors out of line. Like a 3d look.
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 02, 2011 | Sony KP-43HT20 43" Rear Projection...
Hello
  • Screen looks 3D
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Jan 03, 2010 | RCA R61WH76 61" HDTV
Mitsubishi WS-55511 55" Rear Projection Television Logo
397 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
