Question about GE Monogram ZISS360NRSS 36" Built-In Side-By-Side Refrigerator (ZIS-S360NRSS, ZIS S360NRSS)
GE Monogram side by side fridge door vaccuum not working
When I close the fridge door, there used to be a vacuum-type pump that helped seal the door tightly (I could hear it when the door closed). I no longer hear the pump motor and the door isn't sealing as tightly. How/what should I troubleshoot?
3 Suggested Answers
Greg20
  • 149 Answers
SOURCE: I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Posted on Jun 12, 2009
SOURCE: GE Monogram ZISB36DCA only reaches 40 degrees.
I had this happen to mine too. Turned out to be the return spring which pulls the door closed and tight. So door is inadvertantly left ajar or doesn't seal properly. Unscrew the kick plate on the bottom and check to see if the spring broke on the fridge door. It should look just like freezer return spring (which I assume is still ok) Spring can be ordered ... or if only the hook coil came off the end you can rebend it with some difficulty. You need the fabric cover on the spring. Don't throw it away. It is a detent to stop any spring noise when the door is opened and closed. I found out the hard way.
Posted on Jul 12, 2010
My GE Monogram Frig door will not stay shut, it's lost its vacuum seal!
Check the fridge for out of level. Magnets on the weather-stripping hold the door closed. If there is something stuck on the seal, or too much weight in the door in an un-level fridge it will not make good contact. Try cleaning the rubber, and removing everything from the door after leveling. A good seal will stay closed even if the fridge is off.
Feb 23, 2015 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram refrigerator feeezing even when thermostat is set at 45
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jun 07, 2010 | GE Monogram Side by Side Refrigerator
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Condensation in the refrigerator side by side GE Monogram
with the domestic door open hit the door switch and you shoud hear or feel the movement of air. i say you have no air circulation or a blocked condenser drain water is not getting back to the evaporator tray
Mar 28, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
