Question about Compaq Computers & Internet
I get a blank screen when i turn on the monitor
I hooked my hf199h monitor up to a compaq presario and it turns on but nothing comes on the screen
  • Carlos Soto
    Carlos Soto May 11, 2010
    Does this monitor work with another system? On the other hand, I did have a Hans go bad on me after two weeks of having it in service.
    Sergeant:
    Champion:
  • 225 Answers
If the monitor continues to have a blank screen when connected to another PC, then the hardware (internal electronic part/s) is having trouble powering up the panel/ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring the unit to a service center to properly diagnose & fix the problem. best regards
Posted on May 25, 2009
Compaq Presario v4000 will not boot screen stays blank
Overheated chipset/VPU. It needs resoldering.
Oct 09, 2014 | Compaq Presario Notebook
HP Compaq Presario turns on monitor stays blank
Yes it could especially when it does not work on another monitor.
Try another video card.
Sep 22, 2012 | HP Compaq Presario PC Desktop
I have a compaq presario computer using a compaq monitor. I have a Gateway HX2000 LCD flat screen monitor (year 2009) that I want to us instead of my compaq monitor. I have disconnected the compaq monitor...
I'm guessing the different monitors are different sizes? The only thing a driver for a monitor will do will tell the computer the max resolution that the monitor will be able to go up to. However most 90% of monitors can use the built in windows driver without issues. Your best bet is going to be to change the resolution on the monitor. To do this you can either hook up the old monitor, lower the resolution, and then plug in the other monitor. Or you can boot the computer into VGA low resolution mode by pressing F8 as the computer starts up and selecting that option. From there you can lower the resolution, and then put it at something more desirable with the new monitor.
The other possibility being your Gateway monitor is actually malfunctioning and you just happened to hook up a bad monitor.
Mar 27, 2011 | Computers & Internet
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
I turn it on i get white blank screen. same when external is hooked up
Seems it is the Video card which has gone bad, If in case your system shows Compaq on your screen, os in that case need to install windows in the system again.But if it does not , Please get your system's Video card again.
May 25, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario SR2013WM Problem
Unplug power cable from of the PC. Then hold power button in for 30 seconds, this will drain the capacitors, then plug back in the power cable see if this helps, if not could power supply, or video card.
Apr 20, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Kogi l4ax monitor (black screen)
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to fix it. Hope this help!! If anything I can help you with, feel free let me know.
Thank you,
Tan
Mar 06, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
My monitor isn't working
maybe the problem is connection cable between monitor n cpu, try to open n close your monitor. then try on again, if not u have to bring service center
Aug 14, 2007 | Compaq Presario R3000 Notebook
Computers & Internet Logo
152 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
