Question about Dishwashers
Beko dw601 dishwasher won't start! - Dishwashers
Why beko dishwasher wont fill with water
Assuming you can select programs and start it, the most likely problem is water inlet valve. Make sure the water tap under kitchen sink is open.
The water inlet valve looks like this.
Beko DS1054S Solenoid Valve
Sep 03, 2014 | Beko DS1054S 450 mm Silver Freestanding...
Dishwasher not draining BEKO dw601
I had the same problem with a Beko. Turned out to be the impellor pump. Chap who came to me said it was cheaper to buy a new one. Sorry.
Sep 09, 2013 | Beko Dishwashers
My dishwasher does not receive water
You may have a defective/stuck overfill valve. If it isn't operating correctly, it won't allow water into the tub, or too much.
May 12, 2012 | Beko Dishwashers
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
My beko eco care d3421fw dishwasher won't fil with
i have beko glacier fridge freezer.the freezer section works as normal but the fridge section only works sometimes.the pump only starts after you hear a click sound from the back of the fridge.is there a starter component that activates the pump.
May 22, 2009 | Beko 24 in. D3421F Free-standing...
Beko dishwasher wont start it comes on wont fill up
hi there...have you checked the water supply to the dishwasher.......sounds either no water to the appliance or a faulty water inlet valve to the appliance
regards Sir Galahad
May 15, 2009 | Beko 24 in. D3421F Free-standing...
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
How do i re-set my dishwasher
If by reset you mean cancel the programme, then you need to press and hold the start/pause button for about 10 seconds until the drain pump starts to run.
This will continue for about 2 minutes.When it stops, turn off the appliance. When you turn on again all should be well
Nov 30, 2008 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
Owen Barnes
