Question about Xerox DOCUMATE 510 Flatbed Scanner
Document not moving all the way thru ADF.
When I click scan the 510 begins to pull the document into the ADF but then stop at or near the two small black plastic rollers in the curved cover.  It doesn't seem to want to make the turn to feed downward.
  • Anonymous Dec 14, 2007
    DOCUMENT STOPS
    President:
  • 2,072 Answers
The roller and retard pad need replaced. They are simply worn.
Posted on Feb 21, 2008
The paper you scan is stuck
There is debris blocking the paper path in the document feeder. This could be a staple or a shard of torn paper blocking the path wedged into a tooth of the diverter arm or a sensor flag. I would suggest that if there is a small wheel or knob closest to you when you raise the document feed lid, put a piece of #28 lbs card-stock into the document feeder guides, turn the wheel/knob to pull the paper/cardstock into the ADF and continue until it either pushes the shard/debris out or stops moving the paper no matter how much you turn the wheel/knob. This will tell you where in the ADF (Automatic Document Feeder) the blockage is located.
Nov 06, 2013 | HP OfficeJet Pro K8600 Printer
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot clear error message "Document
Hi nigel_lester,
This error message "Document in ADF" that you are getting means that you need to remove foreign object from the Automatic Document Feeder (ADF). Kindly follow the procedure below in clearing document jams:
Document jams in the ADF (Document Tray)
1. First, press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF. 3. Then, open the Feeder Cover.
4. From under the roller to the Feeder Cover side, remove the jammed page.
5. If a document is not jammed, check the document feed area if there's foreign material. If there's any, carefully remove it.
6. Close the Feeder Cover.
NOTE:
  • If documents remain in the ADF after pressing during scanning, [Document in ADF] will appear on the LCD. Press so that the remaining document is automatically fed out.
  • When rescanning the document after clearing the error, rescan it from the first page.
Document jams in the ADF (inner side)
1. Press Stop/Reset.
2. If a multi-page document is loaded, remove any documents other than the jammed page from the ADF, then open the Feeder Cover.
3. Raise the paper release lever (A) then remove the jammed page from under the roller to the Feeder Cover side.
4. Open the Document Cover and pull out the document from the inner side.
5. Close the Document Cover.
Note: When rescanning the document after clearing the error, rescan it from the first page.
Hope it helps.
Thank you for using Fixya.
Apr 02, 2011 | Canon Office Equipment & Supplies
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
I have a Cannon Pixma MX320 all in one printer and I cant get it to stop saying document in ADF
Issue: ERROR LCD: DOCUMENT IN ADF
Solution: Remove foreign object from the Automatic Document Feeder (ADF) - MX310
Check the Automatic Document Feeder (ADF) for obstructions
Follow this procedure to check the ADF for obstructions. You do not need to turn off the power when clearing document jams.
  1. Press <Stop/Reset>.
  3. Remove the jammed page from under the roller to the Feeder Cover side.
  4. Pull out the jammed document from the ADF. If the document cannot be easily pulled out, proceed to section Document jams in the ADF (inner side).
  5. After removing the jammed document or if a document is not jammed, check the document feed area to make sure there is no foreign material. If you find foreign material, carefully remove it.
    Note : If documents remain in the ADF after pressing the Stop/Reset button during scanning, "DOCUMENT IN ADF" appears on the LCD. Press the OK button so that the remaining document is automatically fed out.
    Note: The document may not feed properly depending on the media type, or your environment, such as when the temperature and humidity are either too high or too low.
    In this case, reduce the number of document pages to approximately half of the loading capacity. Another alternative is to scan from the platen glass
  • If documents remain in the ADF after pressing <Stop/Reset> during scanning, [Document in ADF] will appear on the LCD. Press <OK> so that the remaining document is automatically fed out.
Document jams in the ADF (Document Output Slot)
If the document is jammed in the Document Output Slot, pull it out.
pulloutofslot.gif Note: When rescanning the document after clearing the error, rescan it from the first page.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper jams when using the ADF. Canon IC D780
When using ADF
Note:
* Set a document on the Platen Glass if you want to scan it at optimum quality,
* The area (range) within 0.08"/2mm from the top edge if document cannot be printed since the machine cannot scan it.
*Do not load the following types of documents in the ADF. They will jam.
-Wrinkled or creased paper
- Curled paper
- Torn paper
- Paper with holes
- Carbon paper or carbon-backed paper
- Surface treated paper
- Onion skin or thin paper
- Photogragh or thick paper.
1) Remove any documents from the PLaten Glass.
2) Open the Document Tray.
3) Load the document in the ADF.
Load the document with the side you want to copy, or scan face up in the ADF.
4) Adjust the Doument Guides to match the document width.
Note :
Ensure that the edge of the document stack is in line with the Paper Size Mark imprinted on the Document Tray.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Nov 30, 2009 | Canon Office Equipment & Supplies
I need to scan both sides of a document. How is
How to fix my Personal Computer when it show blue page , I want to know what cause it is.
Nov 11, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
When scanning document stops halfway through ADF
Have you tried lowering the resolution of the scanned document?
Nov 04, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Xerox DOCUMATE 510 Flatbed Scanner Logo
148 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
