Question about Cell Phones
Nokia 6805 flikkering - Cell Phones
Flikkers don`t work.Just working when it`s fors
I need more information.
What happens exactly when you try each side when the vehicle is stationary.
ie: Do they work normally?
In not, does 1 side work, or do the both only work for a few clicks?
Apr 01, 2014 | 2001 Mitsubishi Pajero
Left flikker light does not work. front flikkerlight goes on but does not flikker
I would suspect a faulty flasher unit. It has 2 separate circuits for left and right. They are not expensive and its a plug-out - plug-in replacement.
Oct 02, 2013 | Suzuki Motorcycles
Help me plzz i want license key for smartmovie
IMEI - 359380003413344 License key - 6805
Please rate this post.
Feb 16, 2010 | Nokia N70 Smartphone
Acer Travelmate2350 display flikkering
Seem that your screen resolution changed. Turn off the notebook and again switch it back press F8 until it shows a list of option and then select SAFE MODE. Select it and enter into safe mode.
After welcome screen Right click on Desktop and select properties.
You will get Display Properties window.
Then select the Settings TAB in Display Properties. There select the screen resolution as low as you can 640by480 or 800by 600 then select apply and restart the Laptop.
The notebool should work normally as previously it work.
Hope this will be usefull
Thanks & regards
Nanda Kishore.
Jun 09, 2009 | Acer TravelMate 2303WLCi Notebook
If i turn dvd on it says LOADING and keeps flikkering
try to format your hard disc or to reinstall the operating system
Mar 24, 2009 | JVC DRMH50 DVD Recorder
My Nokia 6805 does not recognize the 220Plantronics bluetooth. It recognized it once and then it has not since then. Can you help?
Hi
The driver CD of the said bluetooth is not functioning with ur PC.
If u r using ur bluetooth in more than one port, then also this may not be recognise by ur PC.
Try to use ur bluetooth in that port where u have installed it.
Try another bluetooth.
Thanks.
Supriyo DG
Jun 13, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
