Question about Labtec Notebook Webcam (961401-0403)
Drivers installation hardware - Labtec Notebook Webcam (961401-0403)
How do i turn on my bluetooth on my emachines pc
Click the "Start" button, then choose "Control Panel," "Network and Internet" then finally "Setup a Bluetooth enabled device."
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
Aug 12, 2012 | E-Machines eMachines W2686 PC Desktop
On what basis system drivers are compatible ?
Device drivers are needed to communicate with a hardware device within a computer. A computer program, such as the operating system, sends an instruction to an device driver, which then tells the hardware device what to do. Operating systems typically contain drivers for all types of hardware devices, but they are mostly generic. Finding the drivers that are needed by a computer can be done by finding the type of hardware being used and updating or installing software.
Go into the computer's BIOS to view installed hardware. When starting the computer, press the F2 key or Delete to enter the BIOS. The BIOS will display the type of hard drive as well as the type of CD/DVD drive that is installed in the system. Look in the Device Manager within Windows to see the hardware devices that are installed. Double-click on the "System" icon within the Control Panel and then go to the "Hardware" tab. Click on the "Device Manager" button to see a list of devices that are installed and used by the operating system. Check Windows Update for available updates to on-board hardware devices. Hardware components, such as a video controller and audio controller, can have an updated driver that can be downloaded and installed from Windows Update. Use the installation CD that came with the hardware device. The setup program will install the software and drivers that are needed to use the device. Refer to the manual that came with the computer or hardware component. The manual will list the model number of the device as well as the website of the manufacturer. Visit the manufacturer's website for a hardware device that is installed on the system. Updated drivers to devices are available from a manufacturer to correct problems and to add additional functionality to a device. The site can also be used to find drivers for hardware if the manufacturer is no longer in business.
b>
May 03, 2012 | Microsoft Computers & Internet
I installed YouCam 4.1 in my HP laptop boot after installing it showing you dont have the compatible VGA hardware or drive to run you cam what can i do?
maybe the problem is in your laptops hardware, maybe the you video cards memory is not compatible on the webcam that you buy,or maybe try to check if your webcam has a driver installed on your laptop. to check right- click on my computers icon the select properties, then choose hardware tab and choose device manger this will show all the hardware installed on your computer and all the hardware that needs a driver, usually the hardware that needs a driver is in color yellow and has a question mark sign.. hope this may help you
Jul 26, 2011 | HP VGA Webcam
I downloaded the driver from nvidia and it installs but if i put my card in windows wants to automatically install the graphics card and then it doesnt pick up my installed driver
install card in first dont let windows do anything to try and install
run driver from nvidia if windows still trys to override then download the driver and try everything offline if none of that helps and windows overwrite the nvidia driver then you want to go into device manager and roll back driver to the nvidia one
Mar 03, 2011 | Computers & Internet
After reconfiguring my lap top's os, vista, I have no volume control installed.
Check your hardware device manager.
To access Device Manager, go to Start | Control Panel | System and Maintenance | System | Device Manager (Device Manager is located under "Tasks" in the left hand column of the "System" menu). A list of hardware will display like the one shown below.
Hardware you expect to find is not listed If you cannot find the hardware you expect to find, it is likely the hardware is installed incorrectly. You should power down your computer and locate the physical hardware on your computer. Verify it is installed correctly, and restart your computer. Once you have restarted your computer, Windows should automatically recognize the hardware and go through an installation process. You may be asked to provide drivers during this installation.
If you verify that the hardware is installed correctly but still does not appear in Device Manager, please contact the DoIT Help Desk.
A yellow exclamation mark appears next to your hardware A yellow exclamation mark next to your hardware means the device is recognized by Windows but is not working properly. This usually indicates a driver problem. Update your drivers by following the directions below.
  1. Right-click on the hardware and choose Properties.
  2. Click on the Driver tab.
  3. Click on Update Driver....
  4. Click on Search automatically for updated driver software.
  5. Windows will automatically look for updated drivers for your hardware. If unable to find any, you will need to go the hardware manufacturer's website and download new drivers.
A red X appears next to your hardware A red X indicates that the hardware is disabled. Right-click on the hardware and click Enable. Your hardware should no longer have a red X.
If you are still having problems with hardware after you enabled it, please.
Nedd more help try HERE
Feb 22, 2010 | Dell Audio Players & Recorders
I have an ezonics web cam p10uc, i already downloaded different drivers and installation software but the camera doesn't work, after i plug it in the hardware installation wizard stars but it says that it...
1st You download Webcam Driver. Ezonic Webcam Driver After this install the webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Jul 26, 2009 | Computers & Internet
Audio Hardware Detection
check the website for newest drivers if not you have to reinstall then install sp3 and hope your drivers work again. or just stick with sp2.
Jul 02, 2008 | ASUS P5VDC-MX Motherboard
Video capture hardware
the hardware is already present in your system install the device drivers from the motherboard driver disc you got with the computer this should solve the problem
Apr 14, 2008 | MSI Starcam 370i Webcam
How to install driver
How do I install a computer driver?
Answer: Microsoft Windows users Depending on how the driver has been packaged is what determines how the driver will be installed. Below is additional information about each of the methods developers use to distribute their drivers and how you would install the drivers in Microsoft Windows.
General driver tips
Below are some general insights to help prevent any additional frustration that may be encountered while installing drivers.
Drivers on CD or floppy diskettes:
Almost all computer and hardware manufacturers include a group of drivers for different hardware devices and often for each of the supported versions of Windows. For example, the driver CD you receive with your printer likely contains the drivers for dozens of different printers. Not just the printer you purchased, which means when installing the drivers make sure you're installing the drivers for your printer, not another printer model and that you're installing it for the version of Windows you're running on your computer.
Below is an example of how a file structure may look on your disk.
CD Example:
-PrinterA100
--Win9x
--Win2k
--WinXP
-PrinterA200
--Win9x
--Win2k
--WinXP
-PrinterB100
--Win9x
--Win2k
--WinXP
If for example you had a PrinterA200 and were using Windows XP you would find your drivers in the PrinterA200\WinXP directory.
Downloading drivers:
Almost all drivers you download are going to be a single file if the file is not an executable file it is almost definitely a compressed file that contains all the driver files. In order to install the driver you will first need to uncompress the file. Additional information about how to uncompress a compressed file can be found on document CH000506.
When extracting / uncompressing the drivers make sure to remember where you place the folder containing the drivers as you will need to point Windows to this folder when installing the drivers. We usually recommend users install the driver files in a folder on their desktop as it's an easy place to remember and locate.
Finally, the single file and/or the files extracted from the compressed file can be deleted after you have finished installing the drivers.
Executable
Many computer and hardware manufacturers today are pre-packaging their drivers into executable files or have the drivers installed through the setup file, which means simply double-clicking the setup file or the file you download should install the drivers to the computer for you.
Note: Many developers may package their drivers in a compressed file, which means before looking for the setup file you may need to uncompress the downloaded file. Information about doing this was explained above. If after uncompressing the file it still does not contain an executable file, some type of setup file, or does not install your hardware device continue with the below recommendations.
Finally, if you were successful in installing your drivers make sure to reboot the computer after the drivers have been installed.
Using the have disk option
Often computer manufacturers and hardware manufacturers will also simply place the drivers on the CD, diskette, or download for Windows to find and use during its hardware detection. Below are steps on how to install drivers for a new device and upgrade a devices driver for this type of setup.
Installing a new device
Upgrading drivers for pre-existing device
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager make sure the device you're attempting to install is not already listed from past install attempts. If the device is found highlight it and remove it from Device Manager to prevent any conflicts during the install.
  2. Once Device Manager looks ok reboot the computer.
  3. As the computer is rebooting an install new hardware wizard should appear if Windows detects the new hardware using this wizard you should be able to point Windows to the folder containing your drivers either on the CD, diskette, or the folder containing the files you downloaded.
If Windows does not detect any new hardware open Control Panel and double-click the Add hardware icon to run the hardware detection wizard. During the steps you will have an option to tell Windows you have a disk containing the drivers for your new hardware device, at this point point Windows to the directory containing the drivers for your device.
Once drivers have been installed reboot.
  1. Open Windows Device Manager. Information about how to do this can be found on document CH000833. In the Device Manager locate the device you wish to update the drivers for.
  2. Right-click the device and click Properties.
  3. In the Properties window click the Driver tab.
  4. Click the Update Driver button.
  5. In the Hardware Update Wizard point Windows to the location of the updated drivers on your hard disk drive
Install through the .inf file
Finally, if the above recommendations do not work the installation instructions for drivers and hardware devices are always contained in a .inf file that is located within the drivers.
Locate the .inf for your version of Windows right-click that file and choose the option for install. Note this is a very raw form of installing a drivers and it is important that you make sure you're installing the correct .inf file and not a .inf file for another device or for a different version of Windows. Additional information and tips about locating the drivers was explained earlier in the general driver tips section.
Once you have right-clicked and installed the driver reboot the computer
One of the above three recommendations should have installed / updated the drivers successfully onto the computer. If you're still having difficulties getting the device to install it's possible you're not encountering a hardware issue and not an issue with the drivers. Refer to the troubleshooting steps for your hardware device for additional help and information.
Dont for get to Vote
Merry Christmas....Good Luck!
Dec 06, 2007 | ASUS P4XP-X Motherboard
Labtec Notebook Webcam (961401-0403) Logo
14 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
