Question about JVC GR-DVL505 Mini DV Digital Camcorder
Different formatted tape jvc grdvl20e - JVC GR-DVL505 Mini DV Digital Camcorder
VHS TAPE IS VERY SQUEAKY AND TIGHT AND STOPS WHILE PLAYING
I answered this previously, thinking you were referring to the machine, not the tape itself. See if a different tape (perhaps even different brand) works okay. If not, look at the machine. I have seen tapes go bad, but generally it is the machine (or camcorder).
Jan 30, 2014 | JVC DF420 D-VHS Tape
What kind of tape use the camera?
First, determine the model of your camera, then repost your question, being sure to include that information. Different JVC camcorders use different types of tape. Some don't use tape at all.
Jan 04, 2012 | JVC GR Video Cameras
When I plug my jvc gr hd1u into my laptop to import the video it recognizes the camera, it will allow me to rewind and play the video from the program I am using but the image in black ( windows import and...
Hi, forgive me if I'm telling you something you already know but if you shot video in DV mode then the iLink switch on the camera has to be set to DV. If you shot video in SD or HD mode then it must be set to MPEG2.
Oct 02, 2010 | JVC GR-HD1 Mini DV Digital Camcorder
Do you have video players that I can use to playback analog v8 tapes (PAL and NTSC) and record them in digital format?
I went to the local Sony store and they agreed to convert my 8mm home video tape into digital, DVD format for less than 15 bucks!
Oct 24, 2009 | JVC KV-V8 VHS/S-VHS playback VCR
Sound playback problems
are those old videos recorded from the same camera? you might need a head cleaner for your camera. Try to play the tapes in different camera for comparison test. caution: make sure that the camera's mechanism does not destroy the tape or put a line or dent on the tape's edges. I suggest you convert those videos to digital format before it's too late.
Aug 10, 2009 | JVC GR-D870 Mini DV Camcorder
I need a VHS adapter for the JVC Mini DV tapes
not available - the tapes are different widths for a start, and the two formats use different compression techniques. Adapters are available for VHS-C to VHS because the tape width and the recording format are the same.
Jun 14, 2009 | JVC GR-DVL300 Mini DV Digital Camcorder
Jvc miniDV 28x Optical Zoom
clean all brown oxide off capstan roller with 70% alcohol and Q-tip. Its the skinny silver axle that the rubber roller comes into contact with when the tape loads. This is what pulls the tape through the transport. also clean heads with head cleaner tape. If your head is dirty, the tape will wrap itself around the drum and cause a transport error.
Jul 14, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Camera dead
there is a fuse blown it happens alot just make sure when you send it in that the shop is a certified jvc or a jvc only repair shop some places fix alot of different brands of cameras and sometimes you might not get it fixed right away because of the workload or not at all
Dec 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Usually when the recording is started it takes around 10 to 15 seconds for the camera to recognise and display the duration of remaining tape, if you feel there is a problem, try using different brand tape.
Mar 17, 2007 | JVC GR-D370 Mini DV Digital Camcorder
JVC GR-DVL505 Mini DV Digital Camcorder Logo
24 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
