Question about Estate 24 in. TUD4700KQ / TUD4700KB Built-in Dishwasher
Dishwasher is leaking , maybe at the valve
Dishwasher is leaking, could be the valve. Where can I get one?
  • 6,784 Answers
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective valve assembly)))
Posted on Sep 03, 2009
Hi, I have a Maytag Mdb8959sas dishwasher that was leaking during a normal wash cycle. I pulled the dishwasher out from under the counter and saw that it appears to be leaking directly below the point...
I will assume that you have cleaned gasket around door and at washer. Quite often a build up of scale at lower gasket surfaces is all that is causing leak.
Feb 19, 2014 | Dishwashers
Water leaking out of bottom of maytag dishwasher
Maybe it is leaking from the water valve that is just ouside of your dishwasher, There is a flexible line attached to the water valve that goes into the dishwasher where it is also attached. Get a flashlight and look around, if you see the valve see if the connection is leaking. If it is, see if you can tighten it. You can also shut the water to the dishwasher off here. Don't forget to turn it back on after repairs.
Feb 01, 2014 | Maytag Dishwashers
Miele G2020 leaking 2 spots help
please follow this steps and fix it. God bless you
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.f3a0b0dc-c8b0-4678-bccb-f94392039827.gif
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispenser gasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the water inlet valve.
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pumps Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the tow kick and maybe the front panel to inspect.
Jun 14, 2013 | Miele Dishwashers
GE Profile Dishwasher leaking from the bottom
If your dishwasher is Leaking check the following
Door Seal
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispensergasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case reokace inlet valve
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace.
Door Latch
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Use the VOM. God bless you
Apr 05, 2013 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaks after I cleaned the air pump
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher
Door Seal
Dispenser Seal
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case replace the inlet valve water
Door Latch
The door latched can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
Use the VOM, God bless you76c7517c-e034-47da-bf6c-02b58ecb7551.jpg6274586f-de4d-45f0-bbab-ada21592e251.gif
Apr 05, 2013 | GE Profile PDW8400J Built-in Dishwasher
Kenmore elite dishwasher leaking below washer
see this causes and use the common sense. God bless you
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily. Watch the video on leveling your dishwasher.
Door Seal
Dispenser Seal
Water Inlet Valve
Some dishwashers have separate drain and circulating pumps. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace. Follow the tutorial on replacing the pump.
Door Latch
Door Hinges
Sep 19, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher leaking from underneath
Possible that the drain hose is leaking , the drain valve /pump is leaking or the the inlet hose is leaking. You need to observe with a good light under to see the point of leak and infer.
maybe a hose clip is bad and will need to be tightened or the valve needs to be removed , cleaned and reset.
Apr 06, 2011 | Whirlpool Dishwashers
After cycle is complete and dishwasher shuts down, water seems to leak into dishwasher
if u dont have an air gap the water from sink syphons in ur dishwasher. if u have an air gap maybe ur valve is faulty
Feb 06, 2010 | GE Dishwashers
Dishwasher not filling with water
make sure you didnt kink the water hose,wires on tight.check the float inside the dishwasher .it should lift up and down freely if its stuck up (maybe something is under it) it wont let it fill.good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 26, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
My dishlex dishwasher overflows
The only part that physically allows water to enter a dishwasher (upon receiving power from the control) is the inlet water-valve. I would test the inlet water-valve located directly where you in-coming water line is connected to.
Shut-off power to the dishwasher and remove the 2 prong connection to the water-valve solenoid (small, black, batter size). Test the solenoid for continuity; if bad, replace the entire inlet water-valve (cost about $20)
Jun 15, 2008 | Candy 24 in. CD623 Free-standing...
Open Questions:
Estate 24 in. TUD4700KQ / TUD4700KB Built-in Dishwasher Logo
73 people viewed this question
Top Estate Dishwashers Experts
jdthefixer
Charles T Nevin
Charles T Nevin
ray gallant
Are you an Estate Dishwasher Expert? Answer questions, earn points and help others
