Question about Kitchen Ranges
Gas dryer wont dry clothes - Kitchen Ranges
    Problem Solver:
  • 7 Answers
Assumptions;
The drum is rotating as usual
The clothes get hot or warm so the gas burner is working
If these things are true then check the outside vent for air flow. If it is weak less than expected, I'll guess that you have a clogged vent.
First check the outside vent for buildup. If it is clear then the problem lies somewhere upstream.
It can be messy, with lint blowing all over the place if you pull off the hose from the machine while it is running but if the air is comming out there then the clog is on down the line.
Posted on Jan 04, 2014
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Neptune MDG5500AW Gas Dryer: What causes my dryer to dry clothes one cycle but ...
Believe it or not your ignitor is going bad...
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer wont dry
it may be a defective ignitor/glow coil bad, if this is bad the flame sensor will not see the flame and shut off gas supply, there is enough gas initially to make it smell in the unit though
Oct 30, 2009 | Dryers
Gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Sep 16, 2009 | KitchenAid KGYS750LQ Gas Dryer
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Gas dryer wont trun off after drying
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 08, 2009 | Dryers
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
