Question about Mitsubishi WS-48613 48" Rear Projection Television
Ws48613- loses pix and sound(not power).
Fix by turning it off and then back on. Sometimes this happens every 15-20 min.
Reset doesn't help
  • mklong79 Jan 09, 2010
    I have the same problem and the same exact TV! Did you find a way to fix it?
  • jphasenaur Jan 09, 2010
    I finally got a teck to look at the tv. After 3 hrs. and 3 failed solutions-- he said it was a circuit board that they didn't make anymore. It would cost $950 for someone to repair the board.
    My solution--a 50" Panasonic Plasma
    Thanks everybody
Thanks so much for getting back to me. Hope you enjoy the plasma.
Posted on Jan 09, 2010
97 dodge caravan whines in-between accelorations
lose serpentine belt, adjust or replace it,
Sep 16, 2014 | 1997 Dodge Caravan
Power Doesn't Turn The Computer On
Well if isn't the power supply or the motherboard, it's a boat anchor. You can still use the TX certified sound card in a new one.
Feb 10, 2013 | Dell Dimension 8200 PC Desktop
I lose all power in my 2004 roadstar 1700 when i push the starter button
Sounds like cables are not making a good contact. Take the cables off the battery and clean them and the posts. If that doesn't fix it check the cables at the other ends at the starter and ground. Make sure you take them off and clean them good cause they can be tight and still not make a connection.
May 25, 2012 | 2004 Yamaha Road Star Silverado
Blackberry 7130e. It is showing that it has a signal but i cannot recieve or make any phone calls or texts. It has an arrow flashing at the top by the signal like its sending somthing constantly...how do i...
This problem happens on pretty much any computer-related device. Something happens and you can send anything. It’s annoying, but there are actually two ways to fix it. You can perform a soft reset, which is done by pressing the ALT + CAP + DELETE keys on your handheld at the same time. If this doesn’t work, perform a hard reset. This is done by finding the RESET button at the back of the handheld. Sometimes, this button might be near the bottom, under the battery cover. Press the RESET button using a pin or paper clip. With either method, you shouldn’t lose any data.
Perhaps, is you did not see the reset button,you can also do the hard reset this way, in the process of powering your phone, pull out the battery straight before it finish loading, this helps fix abnormality on the blackberry phone.
Take care.
Jun 05, 2010 | RIM Blackberry 7130e Smartphone
Hi, i accidently opened the battery door cover with the camera still on and now it says "memory card error" and won't take any more pix. how do i fix the problem? thanks
Hello. Turn the camera on and go to the menu. Find reset and reset your camera. This will take you back to the original factory settings. Next you may have to format your memory card. once again go to your menu and find format. Formatting will erase what you have on that card, so if you do not want to lose those pix save them to your computer first. Joe
Mar 02, 2010 | Canon PowerShot A530 Digital Camera
Mitsubishi ws-48613 no power
It seems problem of weak capacitors in power supply and deflection board.
If you have little experience of TV repair and good soldering skills, then check above said boards for weak capacitors.
You also need to have service manual of WS48613 which can be obtained from Manual Zone.
Service manual has schematics and technical information of TV to help in repair.
Dec 12, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Fading and losing pictures
If your TV has more then 1500-2000 hours of usage chances are the power board is starting to fail due to the amount of heat that the parts are expose to when the TV is on. There seems to be a high failure rate on power supplies due to overheating.
The solution to get the TV working properly will be to have a new power board or repair the on inside your TV.
Let me know if you require further assistance.
Jul 26, 2008 | iLO 3200 32 in. LCD Television
36 inch RCA 36v430t
Mike-It looks like the power supply is going on your tv-it can be replaced. This happens, usually, when little kids are playing wth the remote or power button on the tv. Turn it off and on a whole bunch of times in a row, kids love to do that, and it burns out the power supply part- to make a CRT tv like your RCA36 incher- which is a beautiful machine- I have the RCA/PROSCAN 36 incher-LAST longer...You should always wait 5 min between turning it off and on. Don't ever sell it. This one is worth fixing. It has better color and sound Than the new plasmas and lcds-The Pros know this. Be carefull, they might try and talk you out of it-so they can fix it and have it for themselves. So what if it's not High Deff. It's a great set.
Jul 02, 2008 | RCA F36650 36" TV
Mitsubishi WS-48613 48" Rear Projection Television Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
