Question about Westinghouse CW26S3CW 26 Class LCD HDTV - 720p, 1366 x 768, 16:9, 1000
When plugged in, the tv comes on without pressing the power button. Screen is white and there is no response from pushing any of the buttons. Eventually, the screen flickers a little and then it goes off and won't come back on.
  • 87 Answers
The panel is shorted, buy a new tv
Posted on Jan 03, 2014
  • 2318 Answers
SOURCE: White Screen of Death. TV locks up
You will need to replace the power supply or get fix because there aren't too many service parts available anymore.
Posted on Jun 07, 2008
VOTIT
  • 2071 Answers
SOURCE: tv problem
Your problem is in HOT, Horizontal output transistor is defected already ,this is high voltage transistor , if no high voltage there no picture ,but supply is there because light is flashing ,the supply voltage is trap ,when this voltage go to horizontal section your tv is automatically shut off because defected HOT,,you change this transistor ,so performance will better again ..find a tv repairman to do the works in changing the transistor and little reheating works.
This is better in order to avoid high voltage shock,this not cost much....
Posted on Jun 26, 2008
baccardo
  • 150 Answers
SOURCE: Menu constantly pops up on the screen and also flickers on & off
sounds like the logic board could be at fault here
Posted on Apr 16, 2009
SOURCE: White Westinghouse 32 in Issue
hey u wanna sell the lcd screen let me now 916-613-3009 albert
Posted on May 27, 2009
panchal643Ja
  • 243 Answers
SOURCE: tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Posted on Jan 23, 2010
Sony bravia KDL40S20L1 Lost complete video. Still have audio.
First, unplug all wires/cables from the back of the television including the power cable. Then plug the power cable in and using the power button on the television, turn on the tv and hit the menu button on the side of the television. I
f you have a menu, it could be a simple fix (meaning there isn't a bad board, etc).
You could also use the remote control to try to enter maintenance mode to see if the screen works.
Make sure if your remote has four little white buttons under the power button, select TV
With the tv plugged in and OFF (this is standby) press the following four keys in order within a second of each other.
DISPLAY / 5 / VOLUME + / TV POWER
When the screen comes on (even if black) press the JUMP key quickly once or twice.
if you see a menu, the boards should be okay. If not, might be a little expensive or you didn't press the buttons in time.
In general, if you see a menu on the screen, the lcd board and the electronics involved with making a picture should be okay and it might be loose connections
Mar 04, 2013 | Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
There is no picture anymore, all shows a blue screen.
do you have the orginal remote that has device button on it such as tv,dvd,av1,av2 or a input button on it if so play around with it such as when the blue screen comes on press the tv button or even better if you have cable box with the red,white and yellow plug in the back just plug the red,white,yellow cable from your cable box to the red,white and yellow into
the input of the tv
Jul 31, 2009 | Televison & Video
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
Mar 19, 2009 | Sharp LC52D65U 52 in. LCD TV
MagicSing EG-18000 TV picture
i believed the problem is the TV mode. (NTSC or PAL mode)
try this
turn mic OFF
press and hold 8 then press power buton (PAL to NTSC)
or
turn mic OFF
press ang hold 9 then press power button (PAL to NTSC)
customerservice@magicmic.com
Sep 05, 2008 | Magic Sing Along Consumer Microphone
LCD blank screen, blink white
blank_page Use a reset sequence on the monitor-
1. turn off monitor
2. unplug power
3. plug power back in, holding down the last button on the left, then push the power button to turn back on and off three times, holding on the third try until it comes on- hold for ten seconds and release; the monitor should work again
Jul 28, 2008 | Computers & Internet
Closed caption
Closed caption wont turn off was solved by Bresnan tech. He told me the only way was to push the power button on my remote & then push the menu button right away & it would bring up a white screen & cc would be on it. I could't get it to work so I pushed the power button on my remote & the menu button on my motorola cable box & up came the screen & closed caption was on it. I disabled it & it took off the closed caption. Hope this helps
Dec 26, 2007 | Protron PLTV-32 Television
Westinghouse CW26S3CW 26 Class LCD HDTV - 720p, 1366 x 768, 16:9, 1000 Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
