Question about GE GFWH2400LWW Washer
The GE GFWH2400LOWW I own won't drain.
The manual shows a Pour spout on the Pump Filter, but that is not what our unit shows. When you open the access door it comes completely off. The pump filter is covered with a square plastic encasement that I cannot remove. How do I get this off?
  • A Lamb Jan 03, 2014
    Nevermind. I finally got the housing part off. The pump drain had a bit of water but no debris. Any suggestions on why it won't drain. I've checked the drains and they are fine.
    Master:
  • GE Master
  • 676 Answers
Could be something lodged in the pump
Posted on Feb 05, 2014
4 Suggested Answers
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
ladiestch
  • 19 Answers
SOURCE: drain pump keeps running
Probable motor control board problem.
don't buy a GE anything!
Posted on May 03, 2010
FitzOriginal
  • 842 Answers
SOURCE: GE front loading washing machine
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Posted on Jul 12, 2011
Testimonial: "Thank you so much! This washer has not been used because of not draining for over 6 months. Your advice solved the problem perfectly. THANKS SO MUCH!"
My GE gfwh2400loww washer, the pump filter needs to be drained every 1 or 2 times a wash is done..otherwise water stays in, and when you drain it, it smells musty and horrible. I checked the manual,
You should not have to clean filter . Check your hose for clogs ,follow the hose all the way to where it drains into the sewer line. If your sewer line is very high up the pump may not be able to pump out all water efficiently. So some water will flow back down to the pump. If there is a clog up high, the clog will not allow draining. These pumps are strong ,but not that strong. Please let me know what you find. GOOD LUCK FRIEND.
Nov 17, 2014 | Washing Machines
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
GE WSXH208V1WW
Usually when you have a washer that will not drain, first check if the drain hose is kinked or too high above the washer (8 ft is the limit of the washer pump). Next check if there is a blockage in your drain (often a stand pipe) or if the air can't get into the stand pipe. The final thing to check is for foreign objects in the pump to drain hose area that block the drain. (This requires getting into the pump and disconnecting the hose. Keep a bucket ready to catch the water that will pour out of the washer.)
GE has the manuals for many of their appliances on their support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number and click submit. The direct link to the manual for the WSXH208V1WW is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90256.pdf .
I hope this helps.
(at least my washer won't spin if the water can't pump out. On a few washers (non-high efficiency) the solenoid has failed to open for the pump to drain the water.)
Nov 22, 2011 | Washing Machines
Hi my F &P dishdrawer unit (DD603) won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Fisher and Paykel Dishwashers
Ge portable air model APH1GAAG1. Can't find a the water bucket. Has been at 83f for past 2 days. The spout in back leaks water. Home depot suggested I put the unit on small table and bucket...
Call GE customer support at 1-800-626-2005 or... go to this link:
http://genet.geappliances.com/DocSearch/Dispatcher
and enter this model number APH10AA
The manual file is 1.28 mb.
This is straight from the manual page 6:
Drainage/Routine Maintenance
This air conditioner produces water during normal
operation. The unit should be drained if it is not
going to be run for an extended period of time.
The unit should also be drained prior to storage
at the end of the cooling season.
To drain the unit, follow the instructions below:
1. Unplug the power cord and roll the unit to a
drain or outside.
2. Pull out the drain cap and allow water
to drain from the unit.
3. Securely replace the drain cap.
Thanks for choosing FixYa,
Kelly
Jul 21, 2011 | Heating & Cooling
My washer lg wd-3245rhd will not drain, not even from the manual hose close to pump filter.
You have 2 problems. The manual drain hose is plugged with debris and cannot drain out. You will have to pull the hose out and clean it out.
The other problem is the either drain filter is plugged or the drain pump is broken. You will have to pull the drain filter out and allow all the water to pour onto the floor to check the drain filter. If the drain filter is clean, then you have a broken drain pump and needs to be replaced.
Good luck
May 26, 2011 | LG WD-3245 Front Load Washer / Dryer
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
Apr 20, 2010 | GE WSXH208A Front Load Washer
How to clean out the Pump Filter on front load ge wcvh6600
for other models, like the GCVH6260, you remove the lower front panel, which is held on by 3 screws, and unscrew the filter, which is a round white plastic thingie on the right side. (unlike the video, there is no convenient flip down spout for the water to drain out.) be prepared to catch about a litre of water when opening the filter. a good-sized tray or bowl works, and have a cloth or towel handy to mop up any spillage.
slide it out, clean it, and slide it back in. on my machine the closed position was marked with a blue mark along the edge - it's a nylon plug with a rubber gasket, so apparently it doesn't need to be overtightened. just turn it back to the way it was.
Apr 18, 2009 | GE Energy Star WCVH6260F Front Load Washer
GE GFWH2400LWW Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
