Question about Samsung Washing Machines
Sandy residue My brand new top loading Samsung WA50F9A doesn't seem to **** the dirt removed from our dirtier clothing out of the machine. When I remove the clothing, there will be sand in the folds of the clothing and on the bottom of the drum. That translate to sand in my dryer filter. I just replaced my 1979 washing machine and never had this problem with it. I can't find a filter to clean out, have run the "pure cycle" to clean the drum. Any ideas? I am tempted to return it and get my money back.
  • 653 Answers
Are you on public water or a well? If you are on a well, you may need to replace the screen on the well point.
Posted on Jan 03, 2014
LTF6000E - Grey residue remains in gasket after wash.
this could be some dirt form the clothes. tty washing the clothes again and check for the second time.
Sep 22, 2008 | Frigidaire ATF6000ES Front Load Washer
Samsung washer gets clothes dirty
Put a whole house water filter on the cold side of the inlet water. I bet you have well water with lime in it??? Wash your clothes only in cold water. Rub a couple of empty loads with clorox, lime away, oxy clean to remove any build up in your washer
Oct 21, 2012 | Samsung WA5471AB 27" Top-Load Washer, 4.7...
Clothes dirtier after wash than before
hello. the hot water and bleach partially cleaned some of the builtup residue in your tub. If you can find a product called CLR [calcium, lime, rust] use a cup of that in your machine with a few old towels. Run your longest and hottest cycle. Repeat if necessary. Joe
Apr 08, 2010 | Washing Machines
My clothes are coming out dirtier than when they went in, some with dirt smudges, some with dirt dots from the holes in the sides of the tub. Is there a screen/filter I can clean?? What's going on?
Try running a load with NO clothes, only water and a liquid detergent. There likely is a chuck of dirt under the agitator that is filtering particles up into your load. One good fill, wash and rinse cycle should do it.
Sep 20, 2009 | Washing Machines
Kenmore washer Heavy Duty (70 Series) 1985-1989
behind the knob that you use to set the water level is the level control it should have a n adjustting screw to set the water level(you can set it where you want)
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Clothes coming out of washer dirtier than when they went in!
there are two ways of fixing this problem
1. there is a product called CANETAN RINSE it cleans all the nasties out of your machine while you wash
2. an oldey but a goody is vinegar instead of fabric softner as it has a tendensy to gum up machines more often than anything else
instead of using fabric softner try using disinfectant it does less damage to your machine and also the same job as fab soft
Jun 10, 2009 | Washing Machines
Clothes are dirtier after washing...
The problem with your front load washer is a broken rear bearing. If you remove the rear panel, you will see brown "gunk" all over.
If you want to repair it on your own, order this:
Good Luck!
Feb 01, 2009 | Frigidaire GLTF1240A Front Load Washer
Neptune washer detergent department that is on the lid
use vinegar in cleaning it! soap, as it is made of mostly soda dissolves in vinegar.
also vinegar helps remove bad smell on the machine cause by residue dirt from clothes.
Feb 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
131 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
