Question about Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX
Laars lx 250 fault code "AGS"
I've had the unit for about 5 years and have had problems in previous years. In this case the igniter seems to be working fine, the blower works however, there is absolutely no smell of any gas.  The "AGS" fault code comes on.  I have tried it numerous times over the course of two days with the same results.
  • MCPDOG May 25, 2009
    I have the same problem. I was told by a tech from Water Crafters that the Gas valve was bad, so i replaced it at a cost of $200 bucks. This did not fix the problem. Water Crafters ****!
    I have tried bleeding the gas line and turning power of several times to no avail. I'm going to check the presure sensor and temp limiters next but don't know what the reading should be with a digital volt meter. Where can I get a troulble shooting guide?
    Top Expert:
  • Jandy Master
  • 5,075 Answers
Make sure safety circuit is ok that cuts off fan and check pressure switch and hi limits
Posted on Jan 30, 2016
4 Suggested Answers
  • 64 Answers
SOURCE: what does service ags mean on a LAARS LX pool
AGS stands for Automatic Gas Shutoff. This means the heater failed to sense a flame or flame rectification. When this occurs, the the gas valve will close as a safety precaution. The heater will have to be reset to get another call for heat.
Posted on May 19, 2010
StepehnD
  • 78 Answers
SOURCE: My Laars LX pool heater would shut off soon after it fires up
This error is Automatic Gas Shutdown. Here is what you can do:
  1. Check for fluctuating pump pressure (air in strainer, pressure guage bounce)
  2. Check all wiring connections
  3. Replace ignitor/flame sensor assembly
Depending on your expertise, it could also be the gas valve or ignition control (aka the IID).
Since the burners do fire briefly, I would suspect the flame sense rod first. Attached is a link to the owners manual in PDF.
Lo Nox heaters can be a little tough so follow the directions exactly.
Posted on Jul 25, 2010
  • 990 Answers
SOURCE: my laars lx 250,000btu just displayed a "low
Check your baskets for plugs or your filter may be dirty. The impeller may be clogged in your pump if your pump basket is set wrong or if it has any cracks in it. These will all drop the pressure to the heater.
Posted on Aug 15, 2011
I am getting an error code ags
AGS - Auto Gas Shutoff = Because of a problem sensed, the gas valve is closing, stopping gas supply and hence heater shutoff.
Improper water flow through heater! Check filter, pump, water supply lines, anything that will reduce water flow into heater.
A faulty Pressure Switch may cause this problem as well.
or...
In coming water to heater is over 104°
If all is good with the above, replace the AGS Switch.
May 31, 2015 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Blower not working. How to test
if the blower is working when you jumper it at the motor you`ve eliminated the motor itself.if you have replaced the heater control with a new one or known good used one then the only thing is the blower motor resistor has gone bad.i`m surprised you did not check and replace this unit after jumping the blower motor.
Nov 04, 2013 | 2005 Chevrolet Impala
GS550 Electrical Problems.
try carefully shorting a screw driver accross solenoid the two big nuts with ignition on . try a meter on continuity starter casing to earth
Jul 18, 2013 | 1980 Suzuki Gs 550 L
Laars LX 250 AGS Service error. Burners ignite the go out.
if connected 120 volt switch red and black wires its not rectification
Nov 17, 2012 | Jandy Laars Lt 250,000 Btu Heater
IT TURNS ON THEN SHUTS OFF,DISPLAY FLASHES SERVICE AGS
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 29, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Blower switch for a/c and heater on dash only works on speed 4----blower fan does nothing on setting 1, 2, or 3---Would this be a fuse?
you have a faulty blower motor resistor. This unit is usually located near the blower motor under the passenger side dash. It controls the fan speed for a/c-heater etc. They cost around $25-$80 depending on your model.
Sep 01, 2010 | 1999 Nissan Frontier
Jul 24, 2010 | Teledyne Laars Laars Lx Pool Heater /...
Try to start heater and i get a code that says service ags what does this mean
Automatic gas Shut Off . The system Locks out if it does not ignite. Shut the power off to the unit at the breaker then try to start it again.
Jun 20, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy LAARS LX250 - PROPANE, DIGITAL READ-OUT, LOW NOX Logo
681 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
