Ariston aqualtis aqxxf 129
Card
  • 15 Answers
SOURCE: Aqualtis washing machine door locked, need quick release?
yes there is a quick release
the door lock have 3 wires u should connect 2 of them together the first one and the third
but its dangerous if there is kids cause u will b able to open the door while its on
Posted on Jun 05, 2009
  • 89 Answers
SOURCE: error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Posted on Jun 10, 2009
MsMithra
  • 79 Answers
SOURCE: Hotpoint Aqualtis AQGF 149 Error F-05 what does this mean?
F-05 means service switch jammed.
Hope this helps. =)
Posted on Oct 10, 2009
  • 2509 Answers
SOURCE: i have washing machine aqualtis aqgl 129 pm and
Have you selected a program? Is water available? You haven't selected delay?
Then I suspect it may be a faulty door sensor, it wont start if it thinks the door is not shut. Try opening and reshutting the door.
Posted on Jan 27, 2011
tunde007
  • 2382 Answers
SOURCE: Ariston Aqvaltis AQXXF 169 spareparts
Hi, you can get the genuine spare parts with pictures from Ariston directly on this LINK......
Posted on May 08, 2011
Aquatis AQXXF 129 h. what is the error code 08?
It means "heater relay cannot be activated". Troubleshooting guide says to tap the relays to try to unjam them. If that fails, replacement of the main control board is necessary. These washers apparently have a propensity for stuck relays on the newer units.
Aug 15, 2015 | Ariston Technologies Washing Machines
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
Lavadora aqualtis error11
F11: Pump Feedback Missing
Overhaul CN1
Overhaul CNF
Overhaul Pump Connector
Overhaul Pressure Switch Connector
Control Pump Windings
Replace Pump
Replace Card
Dado
Jun 25, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston artxf 129 error f02
F02: Blocked Motor, Short-circuited/Open Tachometry
Overhaul CNE
Overhaul Motor connector
Control CNE Continuity/Motor Connector
Control Motor Windings
Control Tachometry Windings
Replace Card
Dado
Jun 04, 2014 | Ariston Technologies AW 129 NA Washer With...
WHAT IS F12 IN A WASHING MASHINE ARISTON AQUALTIS AQXXF 129 H?HOW CAN I FIX IT?
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Apr 24, 2014 | Ariston Technologies AWD 129 NA Washer/...
Lavadora secadora ariston aqualtis aqm8d error f13
F13: NTC wiring harness disconnected from the dryer system
1. Check the efficiency of the terminals on the CNA connector board
2. Check NTC wiring harness
3. Check the wiring harness continuity of the CNA / NTC connectors
4. Replace NTC
5. Replace terminal board
Dado
Apr 08, 2014 | Ariston Technologies AWD 129 NA Washer/...
Aqxxf 129 What has to be done to correct an f-08 error?
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
Oct 02, 2013 | Ariston Technologies Washing Machines
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Washing Machines Logo
Top Washing Machines Experts
