Vizo sound bar 215 vth flashes standby but there's more. Can anyone help please?
There could be several reasons why your Vizio sound bar is flashing standby and powering down. Here are a few things you can try:
Check the power supply: Make sure that the power supply is properly plugged in and that the outlet is functioning properly. You may also want to try plugging the sound bar into a different outlet to see if that resolves the issue.
Check the remote control: Ensure that the batteries in your remote control are fresh and that it is working properly. Sometimes, a faulty remote control can cause issues with the sound bar.
Reset the sound bar: Try resetting the sound bar to its factory settings. To do this, unplug the sound bar from the power source, press and hold the power button for 5 seconds, then release the button and plug the sound bar back in.
Check the connections: Make sure that all cables are properly connected to the sound bar and any other devices it may be connected to. If you are using HDMI cables, try using a different cable to see if that resolves the issue.
If none of these steps work, it may be necessary to contact Vizio customer support for further assistance.
