Question about Kenmore Oasis HE 27082 Top Load Washer
I have an ol error code on kenmore elite oasis model #110.27062600
  • 125 Answers
SOURCE: kenmore elite oasis he top loader
Is it an f code followed by a 51?
Posted on Jan 21, 2008
TheMobilian
  • 8220 Answers
SOURCE: du error code on a kenmore elite oasis he what
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
Posted on Jun 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: What does the error code F51 mean on the kenmore
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hello, I have a
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
Mid wash cycle shuts down and ol appears....laundry still soaking wet and washer shut off
follow this thread: http://appliantology.org/topic/37774-kenmore-elite-oasis-he-ol-error-code/
Mar 22, 2015 | Kenmore Oasis HE 27087
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Screen say OL on my Kenmore Catalyst Elite. What does oL mean?
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
Feb 28, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Ol error on oassi elite washer
my washer told ol code ,i know that means over load ,put its told me that even when i put small load
Mar 01, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
There is an OL error code on my Kenmore Elite Oasis HE washing machine. It seems as if the washer isn't going through its final spin cycle or something. My clothes are very wet and I've been having to...
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Mar 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
Jan 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
