Toshiba 32a14 codes
How much does a model 32A14 Toshiba weigh?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
It weighs [111] lbs
Codes to check are, 2086,2091,2004,2007. If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/ It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 03, 2014
2 Suggested Answers
SOURCE: I have a Toshiba Model 32A14 tv and need the code for my universal remote so I can program it. We used a Direct TV remote but needed to send it back with the Direct TV box. I bought this universal rem
i look at my manual and find theese codes for toshiba. try it all and choose the best for you:
022 044 094 119 138 139 141 142
Posted on Oct 09, 2012
I NEED tOSHIBA 32a14 CODES?
If your GE remote is programmable, you can use its code search function to find one or more codes that will control some or all fuinctions of the Toshiba TV.
Jun 19, 2014 | GE JASRM24912 Remote Control
I have a toshiba 32a14 TV and an Auvio universal remote. I can get the remote to turn the TV on and off but I can't get it to change the input to the TV
Tv universal remote have it limted to it used and operations,only operate the basic only like power on/off and channels up/down also volume up/down that about it.The tv input video 1 or 2 for IN tv to used are tv personal funcstions only for the tv original remote control only have it functions for.Try the website Remotes.com to buy the tv original remote.
Aug 24, 2011 | Toshiba 32A14 TV
It is a 32A14 model. power to house was cut off, electric people replaced phone poles. when power came back on tv wouldn't turn on, no red LED indicator light lit up, and it makes this chirping sound in...
The tv high voltage "H" horizontal transistor IC is dead.That "H" transistor IC sit out side outer wall of the FBT-the flyback transformer,that the big black block of a plastic,with a red wire with a cap hook up to the CRT-(tv tube).Best take to the shop for repair,because part for analog tv are impossible or near impossible to find and do for the replacement.
Mar 14, 2011 | Toshiba 32A14 TV
Where are fuses on Toshiba 32a14 TV won't turn on
The fuses are located on the inside of the set, remove the back cover and follow the power cord in, there should be a main ac fuse near the cord on the circuit board. Toshiba usually has a second fuse further up the power supply.
Feb 21, 2011 | Toshiba 32A14 TV
I have white horizontal lines about 2 inches at top of my tv
You have some bad grounds on the Vertical IC. In addition to this, in the immediate area of this Vertical IC, are a few bad capacitors. Look for this IC mounted on a large heatsink. It may have seven pins . I cannot remember for sure. I have not worked on this particular TV, so I cannot give you specific locations. But I assure the problem is in this area! If you have some electrical experience you can pull this board out. In this case only the caps need replaced and the IC resoldered. Good Luck and thank you for asking. If you have anymore questions, visit me...Thanks Again! Your south of the border tech!
Apr 27, 2010 | Toshiba 32A14 TV
Dead
Put it on the rubbish. Thanks
Aug 27, 2008 | Toshiba 32A14 TV
Toshiba 32A14 horizontal line
This symptom is characterized by a thin horizontal line in the middle of the screen. This symptom is caused by the absence of the deflection sawtooth current in the horizontal deflection coil.
The trouble is easily isolated by a continuity test and by checking the most likely defective components such as A)open vertical linearity compensation transformer, B) open capacitor and C) open horizontal deflection coil.
Be sure to decrease the brightness first before trouble-shooting if the line is very bright,as it burn the phosphor screen..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 19, 2008 | Toshiba 32A33 32" TV
Toshiba 32a41 has power, no pic or sound
please clarify it are you getting light? power button will not turn it off means what.
Sep 25, 2007 | Toshiba 32A41 32" TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
