Question about Frigidaire Affinity ATF7000E Front Load Washer
Err won't clear
  • Official Brand Answer
  • 4,342 Answers
Bill Fortney,
I see that you're getting an Err that will not clear. I suggest trying to reset the appliance for at least 3 minutes. You can do this by either unplugging it or cutting the power at the circuit breaker. Once the 3 minutes has passed, plug the unit back in and try running it again. If you're still receiving the Err, I would personally suggest contacting a professional to accurately assist with the repair.
-Best Regards-
Posted on Jan 08, 2014
My canon iR2016 has a system error E001
the e001 is error for temperature rise by main thermistor. If the termistor OK and doesn't need to be replaced you can clear the error in service mode. If clear doesnt helps, you need to change the fixing film assy.
Clearing error:
Press the User mode key, 2key, 8key,
User mode key sequentially
now you are in service mode, by arrow right, select #CLEAR, press OK, choose ERR and OK.
Also you can try with same procedure but instead ERR choose ALL. NOTE: under clear ALL, you delete all user data and restors the copier on factory settings.
Hope that helps!
Aug 25, 2011 | Canon Office Equipment & Supplies
ESP-6TM Sprinkler System - Everything on the display is correct. Then the unit reads "Err" and will not activate. Tried reprogramming with no luck. What is the problem?
When it gives the "ERR" code, usually it flashes the zone number after that. This will only do this when the system is set to "ON". Sometimes, error codes pop up for no apparent reason, with no fault in the system, and attempting to clear the alarm is the first step in troubleshooting the system. When turned to "ON", and the "ERR" alarm is displayed, hit the ENTER button. This should clear the alarm for a single zone. If another ERR is displayed, clear it also by pressing ENTER. Turn the system back to OFF, wait 10 seconds, then turn to ON. If no ERR codes are displayed, the system should cycle properly on next use. If ERR odes are still displayed, make another attempt to clear them, and re-check. If they cannot be cleared, trace down circuits to the valve boxes for each zone, and make sure that all wiring connections are good, dry, and tight. Solenoid valves can be removed with the water shut off, and tested at the control box by wiring them into the terminal strip site for a known good circuit, and then operating that circuit. If the valve is good, you'll see and hear the diaphragm move.
Best regards, --W/D--
Jun 02, 2011 | Garden
I am getting e020 error switch main off and on again and again
e020 error is of the main fuser unit u can solve it by press *28* then goto copier then function then clear and clear err dc-con err-hist jam-hist and pull both 1st and 2nd drawer now restart and when the screen is ok again restart then on main screen insert both drawers ur err will be removed -tushar sharma tushar@easy.com -9403343433
Mar 22, 2011 | Canon imageRUNNER 600 Printer
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
When start is pressed ERR LOC displays, door
You can try clearing the code and then running the machine. Try colding down the pause and clear button simultaneously for three second s and the faul should clear Or try turning the knob around 9 times to clear the fault.
Jan 08, 2010 | Frigidaire ATF6000ES Front Load Washer
When trying to graph anything, ERR: INVALID DIM appears..
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
Starts beeping and F31 ERR flashes
Any F code error indicates a fault has been detected . Press Clear/Off to clear display and stop beeping then reprogram the oven. If the fault reoccurs record the fault number press Clear/Off and contact an authorized service agent. If you have access to the internet you can download a manual for this appliance go to www.frigidaire.com/support/support.asp
On the customer services page click on product manuals and you will be abe to download the manual and print it off.
Apr 21, 2009 | Frigidaire FEF352 Electric Kitchen Range
Err err err
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Err Err err err err pau
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
