Question about Quasar SP-2725 27" TV
Narrow screen My lg crt tv screen is alittle narrow above and bottom.I think it can repair with remood code.Please help me.Thank a lot.
    Top Expert:
  • Quasar Master
  • 74,468 Answers
You're discussing about the less in height to picture; I assume. How old is this TV? If it is older than 3 years or so, you have to check all the electrolytic capacitors used at its vertical scan output section circuit. There will be usually 5 or 6 of it. Replace all of it at one time, and check. You have to open the TV, and have to solder these capacitors, and solder with new ones in place. It will be better to contact any service technician. The components said above won't cost more. Mind about the service charges. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 03, 2014
How to unlock the locked key. LG TV
A lot of the main codes are 1234 or 0123 or longer in sequent (12345) give those a try...if no luck write back I will research.
Feb 21, 2011 | LG DU-27FB32C TV
When I hit power on the TV it never comes on. There is a red blinking light that is flashing on the front of the tv that says stand by/timer.
You need to count how many times that light is blinking. This will give you the trouble code that the tv is giving you. This helps narrow down the problem significantly. The tv is in need of repair.
Thank you,
Lee
Nov 29, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a sony 51 " rptv. the on screen image arcs on top and bottom towards the middle of the screen he sel diagnostics showed 1 timw akb and 1 hv. the timer blight has been blinking 4 times then stops any...
Ok,
4 times blink is error code for Vertical Deflection problem and you need to check +15 and -15 volt supplies on D board and IC8003 is suspected.
Needless to say, check above in case you have enough knowledge and experience of big TV repair as high voltage shock risk is involved.
Thank you.
Dec 14, 2008 | Sony KP-46S25 TV
HS500, white/light at top of screen
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My apex tv is locked.
You have to hold the button that looks like a flag (top left) and press either the mute or video button. I don't remember which one
Jun 08, 2008 | Apex Digital AT2708 27" TV
Problem in my HITACHI CMT2153 TV
hi, the problem is in the vertical ossilation if only u can trace the bad component.. let me know
Jan 10, 2008 | Televison & Video
LG telivision
  • please go to LG service centre rather than going to local repair centre.
  • as i think that they give first service at some concession rate.
  • i do not think it is much.
  • as no part in tv is that  costly
  •  except crt which is rarely fails in two years time.
  • please call them they will come to your home and will do that.
  • it is not major problem.
  • hope this will help
  • good luck.
Oct 11, 2007 | Televison & Video
Screen split with black bar through center, top of picture shows in bottom
It sounds as you desribe, the vertical output IC and or the b+ feed capacitor off the Hi voltage transformer feeding the vert. IC its required voltage. Not a really hard job to replace, but not for a handi person to do. This should be left to the professional, as there are no user serviceable parts inside this set and with the HI voltage and the safety issues its best to call somesone to assist you with this repair. Good Luck
Jun 14, 2006 | Sanyo DS31520 31" TV
Quasar SP-2725 27" TV Logo
35 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
