Question about Miele 24 in. G665 Built-in Dishwasher
Miele dishwasher leaks when door opened and end of wash
    Novelist:
  • 269 Answers
Do like the others said. This is what I call the Miele Problem!
This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr.
In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary!
If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop.
Doggone design sucks on an otherwise nice machine!!
Posted on Jul 27, 2014
  • 4 Answers
SOURCE: Miele G868 dishwasher - leaks from front panel air vent
Hi all,
I have had the same problem. Here is what I've done. Take the door apart (a whole bunch of screws on the side of the door). The front panel will come off and you will see a rubber tube. Take it off and blow it out. Then take the blower out (you need to unscrew the inside of the blower). Take apart the blower and clean it out.
Good luck.
Posted on Oct 15, 2008
  • 14 Answers
SOURCE: Miele dishwasher drying problem
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Posted on Aug 26, 2009
  • 177 Answers
SOURCE: The drying vent on the front of our miele
if you remove the door panel you will see a small hose from the fan to the combi dispener. Remove this and blow through it. Also connect it to the combi dispener and blow and then to the fan end and blow. Food and muck block the pipe and the excess water cannot escape back into the unit so instead it pours out the vent. you will find the fan is then quieter.
Posted on Mar 02, 2010
  • 70 Answers
SOURCE: Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Posted on Jun 30, 2010
SOURCE: My Miele Turbothermic dishwasher (7 years
mine does the same! Did you ever find a solution? Tx!
Posted on Jul 23, 2010
I am looking for a new door seal for my Miele washing machine. its a brilliant machine but is leaking badly now. model W1712. your assistance in finding one for me would be very much appreciated.
Hi.
Miele make an excellent machine and I would advise you to have the door seal replaced by an experienced technician. The job is not as straightforward as it might appear.
I suggest you contact 2 or 3 repair people and check prices. Try to get some idea of the final price because the labour cost can be open ended and a big surprise...
I generally allow around an hour for a door seal replacement. It can take longer.
Good luck,
Nomess
Mar 03, 2015 | Miele Washing Machines
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Foul odor coming from Miele dishwasher
hi,
if you put the unit on the hottest wash this will kill off the odour. after each wash leave the door open for about half an hour so it dries out and doesn't smell. Also make sure the filter is clean and the door seal is clean. this should all help with the odour
Aug 22, 2010 | Miele Incognito G818SCVi Built-in...
Following the wash cycle with my Miele G464SC
sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
Jan 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Mar 15, 2008 | Miele Dishwashers
Miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Mar 15, 2008 | Miele 24 in. Novotronic Premier 500...
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Water from airvent after wash
We had this problem and when we checked the drain pump it was not turning properly because of hairs wrapped around it
Jun 22, 2007 | Miele 24 in. G665 Built-in Dishwasher
Miele 24 in. G665 Built-in Dishwasher Logo
77 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
