Question about Brady 42001, Handimark Portable Label Maker
Load new supply 2 - Brady 42001, Handimark Portable Label Maker
Why does nail gun not fire? Safety works ok. Gun loaded with 2 1/2" finish nails. Trigger safety switch is off. Slight hiss of air when trigger depressed but does not fire.
Hi Charles & Floyd:
Just a couple of thoughts that may assist.
First. This is an air tool so it is DANGEROUS! Treat it like a LOADED GUN.
Here's what I would do:
- Disconnect from air supply - point away from anything I don't want to hurt, and squeeze trigger. Press safety against block of wood and squeeze trigger.
- Now that I know it is safe, I would remove the nails from the magazine and check that none is stuck in breech mechanism.
- Check that feed spring/latch has released. Sometimes if loaded too full it can catch.
- Load some nails, check that they are the correct fit, and are sliding in the magazine.
- check air supply pressure. Should be between 80 and 100 psi.
- reconnect air supply and try again.
- If it does not fire it may be that the piston is not fully retracting. Since it is new, I would be returning it to the store where it was purchased.
Hope this helps.
Apr 18, 2016 | Porter Cable-Cable FN250C 1-inch...
How do I install patches?
Download n install 2 softwares for G2 from ZOOM website.
1. USB subsystem. Driver to connect zoom fx to PC/Notebook.
2. EDIT & SHARE. Software to create/copy sound patch.
Connect USB cable from G2 to PC/notebook.
No need adapter power supply, because the power is supply via
USB cable from PC/notebook.
Open EDIT & SHARE. It's easy,like copy,paste,rename,delete etc.
Just open the menu that you want to do and follow the
instructions. Sound patch can be load from files that you
download, or create it in EDIT & SHARE.
Patch can be load one files or group. Right Click the sound that you want to change,copy-paste it from new file/sound.
You can import/export files/patches from/to PC library (downloaded files).
It is recomended that you save/backup your original files,before load new sound.
I hope this helps.
Regards.
Aug 31, 2015 | Zoom G2 MultiEffects Guitar Pedal
I just purchased a C8FB compound miter saw , it had no switch, i have new switch but no idea where the wires go?
Hi, all a switch does is break the conection from supply to appliance
in most of these saws it can be pretty simple, assuming it is not
three phase you will have six wires 2 brown 2 blue and 2 yell/green
he switchitself should have six conectors , these can be marked
(L) live brown (N) neutral blue and (E) earth yell/green.and may say
load or supply now , the supply is the cable going into the machine
from the plug , and the other cable is the load....T.C.
Mar 19, 2013 | Saws
Ultra 750 watt power supply ,+12 dc volt output showing ac component of 1.5 to 2.7 volts on new unused ps
Is this with or without a load?
There is always some ripple on the DC output of a switching mode power supply, and the less the load, the greater the ripple.
Measure the power supply under full load, that's the real test!
Feb 26, 2011 | Ultra Computers & Internet
I put a new power supply in and my screen says ntldr is missing why?
test the leads that attach from your motherboard to your hard drive or replace them there probably old and faulty
make sure that you have secure connections to all drives cd/dvd 3.1/2 inch floppy and hour hard drive one bad/faulty lead can lead to lots of probems ntldr is the software that helps your operating system load
Oct 31, 2010 | Compaq 220W Power Supply for PDP-121P...
My husband is trying to wire a new pressure switch for our well. It is located under our home. Can you explain how to rewire it. There are 2 black wires and 2 white wires. We need to know which is the...
The pressure switch is marked for LINE and LOAD.
Line wires come from your power supply to the switch.
Load wires come from the switch to the well pump.
Most likely the black AND WHITE wire from the power supply go to the 2 center terminals on the switch.
The black AND WHITE wire from the well go to the 2 outside terminals on the switch.
Aug 28, 2010 | Kitchen Ranges
Which wire is the 'ON-PS' switch for the Astec Model SA145-3435 power supply?
I found out that the AT supply SA145-3435 does not have a switch wire like an ATX supply. I have a SA145-3435 my self. To get it to work it must have a +5 volt load (BLACK and RED) and a +12 volt load (BLACK and YELLOW). If it does not have both of these loads it will power down after a 2 second delay when you plug it up. I used 2 small 12 volt bulbs. One for the 12 volt line and one for the 5 volt line. The type of blub I used was a #94 I got from the auto parts store.
Oct 01, 2009 | Dell 145W Power Supply SA145-3435...
Dim monitor
Hi
You just bought a new power supply for the monitor? Did you set the B+ voltage to the correct settings. Rebuilt power supplies for CRT monitors are not set correctly at the factory. Use your schematic to determine the proper B+ and then set this under load.
Thanks
Jul 21, 2009 | Toshiba Tekbright 15" CRT Monitor
Computer keeps re-booting while installing any operating system
Were the two power supplies you tried inclusive of the original failed drive or not. In other words did you try a total a 3 power supplies including the one that failed?
If not, please do so. That is, immediately analyze the original known part failure, the power supply or its connection to the board(s) you have tried.
Congratulations for such an exhaustive process of elimination.
Apr 21, 2009 | Tyan Trinity S2090 Motherboard
Brady 42001, Handimark Portable Label Maker Logo
238 people viewed this question
Top Brady Computers & Internet Experts
David Payne
David Payne
Are you a Brady Computer and Internet Expert? Answer questions, earn points and help others
