Computer will not boot and the only screen that comes up is authentication asking for password.
Some how you lost the Operating System Boot Sector. If you had full function prior to this message notification; then a virus, power surge, or other event occurred and took out your operating system. If you want to check the Laptop Hard Drive outside of the computer to see if you still have Pictures, Music, Documents, etc.; you will have to open the back (Bottom) of the laptop case, remove the hard drive, and place it into a docking station or external hard drive USB connection. For a few dollars, TigerDirect on line has them. Once you have a USB attachment device, go to another computer, plug it in and seek that device. If it comes up missing your data, then you know the drive was cleaned out and it needs to be reformatted for use in your Laptop. Go back to the laptop and put the Hard Drive into the computer (make certain it is OFF) and place your Operating System (Win 7 or 8.1) in to the CD Drive and follow the progression from there. I suggest getting Win 8.1 as it is far better than all the other editions.
SOURCE: Dell Inspiron 700m asks for password on startup
You're not going to find out on the web. Click below to check it out.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=E21A18454B4A6550E030A68F27286358&journalid=5F0C99FE5E99ACCDE040AE0AB6E10E45&Query=cmVzZXQrYmlvcytwYXNzd29yZA==&SystemID=INS_PNT_PM_700M&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Good luck.
You need to contact Dell tech support they are the only one has access to the master password of your computer.
SOURCE: Dell Inspiron 6400, asking for HDD password
Insert OS cd in drive and start reinstalling by selecting repair mode
now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now
you will come to old screen and previously configured desktop with all
intact aplication and icons on desktop and it will no more ask you for
password till you set a new one
Thanks and regards
Kindly rate this solution
SOURCE: i need the administrater password to my dell inspiron 1525
You said that whe you first turn ON it is a BIOS password, not a wondows password?
SOURCE: MY DELL INSPIRON N5030 IS
Here is a post about all kinds of laptop password reset, you need it!
http://www.windowspasswordsrecovery.com/hack-computer-login-password.htm
If you have forgotten Windows administrator password then it is difficult to recover so you need to reset it. You can use manual password recovery methods or password recovery software (such as stellar phoenix password recovery software) to do so.
heres directions on resetting in safe mode if the battery fails
Hold F8 as the computer boots before the os boots and then select Safe Mode option (not the others) The computer will boot up from here, but there should be an additional "Administrator" account. Log in to this account (There shouldn't be a password, but if there is, try "admin") and navigate to the User account panel in control panel. From there, select your account name, and select the "Remove Password" option
