Question about Frigidaire Affinity ATF7000E Front Load Washer
Where is the filter located on the affinity front load washer
  • Official Brand Answer
  • 4,342 Answers
Hi Kimberly,
I understand that you're trying to find out where the filter is on your affinity washer. You have to take the back of the washer off --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
http://www.frigidaire.com/manuals
Posted on Jan 08, 2014
onthejob5130
  • 640 Answers
SOURCE: My front load washer affinity pauses 3 or 4 times during a cycle
the unit is waiting for something,,,like water ,,,or a slow drain..you must see where the unit is ,in the cycles,,and make sure that action the unit is trying to do is able to do...onthejob
Posted on Feb 01, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
SOURCE: where is the filter located on a frigidaire
You have to take to back off the washer --be careful because the metal on the edges are sharp. The basket is located on the very bottom of the mechanical parts (sorry I can't be more specific) It is a strainer basket and fairly easy to remove and replace. Frigidaires' website has a schematic of the newer models to make the basket easier to find--I will try to attach the url for mine so you can find it.
Posted on Aug 01, 2009
  • 1382 Answers
SOURCE: What does the code E10 mean? The washer flashes
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Posted on Jun 28, 2010
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
Put the filter back on, affinity
Which filter are you speaking of? The coin filter trap in the pump area?
Jul 31, 2012 | Frigidaire Affinity ATF7000E Front Load...
How to clean a affinity frigidaire front load washer drain pump filter?
remove the toe kick panel just below the front door and its located right below the drum
Oct 01, 2010 | Frigidaire Affinity ATF6000F Front Load...
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
Where is the filter located on a frigidaire Affinity washer ?
Jul 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer doesn't start
May 11, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Affinity Washers
Your Drain Is clogged, Try cleaning the drain filter underneath the Drum assembly. It will take some skill however.
Joe the Plumber
Mid-Hudson Heating & Plumbing
845 679-9158
Jun 14, 2008 | Frigidaire Affinity ATF7000E Front Load...
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
