Question about Generac 13,000 Watt / 13,000 Watt Home Standby Generator
Generac overspeed fault - Generac 13,000 Watt / 13,000 Watt Home Standby Generator
3 Suggested Answers
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 15000 portable generator: during use the motor revs extremely high and then shut off occasionally.
The reason its shutting down, is probably because its going in to overspeed and the safties are shutting it down to protect the engine. is it doing it under a load or no load.
Aug 13, 2011 | Generac Electrical Supplies
I have a generac 22kw model QT02224anan that will run for a few minutes then shut down , then the over speed led is lit. It only happens when it is under load or during a power outage. it goes through...
its possible the overspeed is set to sensitive. or your rpm are to high. these are preset in the factory as a safety, check your manual to ensure your rpm speed is in the pre set area. generators will do this under load when you have a big load on them or take a load off. the governor will some times over compensate causing it to trip on overspeed.
Aug 10, 2011 | Generac Power Systems Generac QT02224 22...
10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Apr 06, 2009 | Guardian Electrical Supplies
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac 13,000 Watt  / 13,000 Watt  Home Standby Generator Logo
26 people viewed this question
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
