Question about ASUS Ve248h 24-inch Led Monitor
Music accompaniment will not stop playing
Connected new monitor and irriating music came on and will not stop
  • 1,511 Answers
You Monitor may be picking up a Radio Signal, just as if it were a Radio. Move it around and se if reposition it helps.
Posted on Jan 21, 2014
How do i stop buffering of Google play music from buffering on my I phone 5s. It keeps stopping and started during playing
3g is slower than 4g is slower than WiFi (most broadband).
Connect to a faster network and retry.
Sep 12, 2014 | Apple iPhone 5S
Turn off accompaniment?
go to the utility settings, accompaniment settings..turn off.
Apr 09, 2014 | Roland FP-80-Digital Piano
One speaker stopped playing bass
Sound like either the crossover or the driver has blown or, if you're lucky there is a loose connection internally if you have only checked external connections.
Jun 01, 2013 | Mackie MR5 MR5 Reference Monitor
My JBL plays but it cuts the play back frequently like it plays and stops, plays and stops, plays and stops so on .Whats the problem. Please help
Until this is fixed, I would not use it or you may blow up a speaker... Make sure you check that you are using BALANCED audio interconnect cables, either XLR or TRS balanced cables AND that ALL interconnected equipment is poowered by the SAME receptacle... yes you have to run extension cords, but the pro's do it to avoid ground bounce damage to their equipment. Use ONLY three wire power cords.
Aug 06, 2011 | JBL New Jbl Prx512m 12 Powered Monitor...
Yamaha Keyboard psr-s550: page 32 of maunal says "when style is off" but then never says how to turn style off. please advise, thanks
Turn off the "ACMP" button... that is the "Accompaniment" function that controls whether the "Style" you select will accompany your playing or not...
Jan 24, 2011 | Yamaha PSR-S500 Digital Keyboard
Midi keyboard sound quality bad
you are likely running it thru a soft synth. Check the help files there is a section in there on "using soft synths" that will explain it more fully. Plus a usb connection can sometimes be problematic (not always). But the tutorial in the help files will tell u how to use the sounds from the piano instead of the MIDI sounds
Dec 17, 2008 | Cakewalk Music Creator 4
Technika FM In-Car Transmitter loud low frequency hum
This humming noise is the cause of a bad ground. try a new grounding location. The shorter the ground wire the better. Make sure the connection is metal to metal. I have had the same problem out of competition systems. Good Luck
Jul 20, 2008 | Car Audio & Video
D80
Make sure you have set the camera to the appropriate mode under the Set Up Menu -- choose NTSC or PAL (for USA it should be NTSC.)  Ensure the proper connections are made to the TV -- Yellow to Video and White to Audio (the camera plays music to accompany your photos).   Make sure your TV is tuned to the proper video channel, which is usually 3.   Now you can turn the camera on.  Now go under the Playback Menu and choose the folder your photos are located in, usually "Current" Now, since there are quite a few options from here, check on page 75 of your manual under Slide Show, and you will see the various options available, such as choosing the music to play.
Mar 26, 2008 | Nikon D80 Digital Camera with 18-135mm...
No Real Time Sound from USB Port in Headphones
The problem is due to the design of the DELL Laptop itself. It is not dsigned to monitor the incoming signal. I bought a cheap Behringer UCA202 USB-Audio Interface. It provides for real time monitoring the incoming sound. I can also hear the accompanying music while I play along with pre-existing tracks. It's not the highest quality but it was only 25$ so well worth the price.
Oct 18, 2007 | Compaq Presario Notebook
ASUS Ve248h 24-inch Led Monitor Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
