Question about Ovens
What does error code 5 on dro2gh mean - Ovens
What is a error code F/19 mean?
That error means that the lower oven is not heating fast enough. IT should rise to over 150 in 5 minutes. Check the broiler and the baking coils for continuity. If they are ok then check the radiant heater in the convection fan housing.
May 12, 2015 | LG 30" Built-In Double Electric Convection...
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
Error F68, beeping continuously
Hello Rasheda, this is Z. Thank you for your post!
If you are getting an error code F68 on your Electrolux oven, it typically means that your appliance may be experiencing an issue with the incoming line voltage. One of the best ways to determine if this is a false error code is to rest the power to your oven by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech since this is not a simple DIY job. He/she would need to determine whether the problem rests with the power supply voltage or EOC (Electronic Oven Control). I hope this helps explain the error code you are receiving.
Apr 10, 2014 | Electrolux Ovens
I have a kenmore elite oven what does an error code F-3 mean
Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Oct 03, 2011 | Kenmore Ovens
Tried to Auto Clean. Got error message: Door -F-5. It started to warm up but would not lock. What to do? Manual not to be found in house. Oven is about 13-15 years old. First problem I have had.
The F5 error code means that the control board has detected a error within itself and the control board needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button but if the error code returns the control board would indeed need to be replaced.
FYI when ordering the control board it also may be called the clock or eoc
GENE
Sep 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Our oven read a problem # E6 F2 what that's mean?
The E6-F2 error code means that the control board thinks there is a problem with the cancel button on the touch pad. Sometimes its due to a loose connection from the ribbon cable on the touch pad. You can push cancel and clear it and if within 5 or under the error code returns the touchpad needs to be replaced. But first check/have the connection checked to make sure its tight. The way modern things work though is grand and Whirlpool say if after replacing touchpad the error code returns once again the clock/control board is what needs to be replaced.
Gene
Aug 11, 2011 | Whirlpool RBD305PD Electric Double Oven
I'm ghetting an F-5 error code on my whilrpool oven. What does this mean? How do I fix it? Thanks for your help
Hi
Error code F5 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a 5 year old Kitchen Aid duel fuel slide-in range. I have used clean twice since I got it. I tried to start clean today and it all went fine until I noticed after about 30 minutes that it was not...
Hi Cynthia
F5 error code normally means control board or clock failure. It means you will have to have a new control board and clock fitted.
Dec 18, 2010 | Ovens
What does the F 5 error message displayed on Frigidaire - 24" Built-in Single Electric Wall Oven FEB 5 56cbs mean?
Hello there:
Here is what the code means and what needs to be dne to resolve this problem
F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control)0dd70e1.jpgShould be something like this
Jun 05, 2010 | Frigidaire 24" Built-in Single Electric...
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
