Picture adjustment the picture on HD is stectch to much
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 14 Answers
If your vertical section of your mother board has a vertical adjustment trimmer, adjust it to reach your desired vertical size..if doesn\'t have, increase the resistance of the resisitor only connecting from cold ground to the negative of the e.cap and the positive pin of e.cap connecting to the line 1 of the vertical focusing coil. the common value of the resistor you would focuse is 1ohm, try add with .5 or 1 ohm depending with vertical size result.
Posted on Jan 04, 2014
How do I adjust the picture on my LG lcd tv it is too large for the screen?
On my LG (32LD320H)
The control is under
  • Menu > Picture
  • Aspect Ratio: (16:9 for most HD content. Use 'Just Scan' or 'Set by Program' for auto sizing.)
  • You may need to adjust your cable box or DVD for HD and matching display parameters.
Jan 22, 2015 | LG Televison & Video
Picture adjustment for JVC HD52G886
Here is the manual http://www.retrevo.com/support/JVC-HD-52G886-TVs-manual/id/279ci059/t/2/, also may need to go into picture advance settings to do some calibrations.
Apr 02, 2012 | JVC HD-52G886 52" Rear Projection HDTV
How do i adjust the picture on a GE D52GW12 52 in. Rear Projection TV? The picture is too large.
There should be a zoom button on the remote control. Each time you press it the size of the picture changes. If there is not a button on the remote, there should be a on screen menu display that allows the size to be adjusted. If you are using a HD cable box or HD satellite receiver, they also have picture zoom options.
I hope this helps
skyassoc
Dec 10, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
Have problem getting a good picture even when making picture adjustments on va26L LVD TV
Hi my name is Roety,
I can help you with your issue ,
These TVs are designed for HD.
Make sure you have an HD signal
set every adjustment dead center and picture/contrast to max
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 30, 2009 | Televison & Video
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
Adjust picture
If it's a Magnavox, That's what your post is under, then good chance the picture tubes are getting a fungus growing inside the blue and green tubes. The sharpness will be lost as well. Need the tubes cleaned inside and then new fluid replaced. Take a minute to search 51MP392H magnavox, I answered this problem several times the past few days.
Dec 08, 2008 | Philips Magnavox 51MP392H Rear Projection...
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Lg 37in the picture cquality in hd is sometimes fuzzy
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to swith to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate. I hope that helps :o)
Jan 15, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
