Question about Coffee Makers & Espresso Machines
My Krups coffee maker does not turn on. Clock works, timer works, but when it goes on, it beeps 3 times, then 3 more times, then just flashes gibberish. It's an FMF5.
  • 2 more comments
  • rshrout May 23, 2009
    I understand that normally it goes through 2 series of three beeps to indicated it's done. In my case, it's simply not done. It has not brewed anything.
  • rshrout May 24, 2009
    Hey, it's a Krups FMF5. I'm able to set the clock and timer. Timer comes on, coffee machine goes not further, does not brew. It flashes a bunch of incomplete dashes, not numbers.
    Programming works fine . . . clock and timer. Just does not come on, either with the timer or by pushing the on button. Does the beep thing twice and just flashes incomplete dashes, no readable numbers.
  • rshrout May 25, 2009
    Yes . . .b==d. Nice idea, but if I can't get it to start, there's no way to run the solution through a brewing cycle to descale. Hmm.
  • 230 Answers
Firstly try and remove and clean the water filter. Then manually descale the machine as good as possible.
Here is the descaling procedure from krups:
• Before descaling, remove the filter holder (k).
• You may use either the Krups descaling solution diluted in 8 ounces of water or 8 ounces of
white vinegar.
• Pour the solution or vinegar into water reservoir (b) and start the coffee machine (without
coffee).
• Allow half the liquid to run into the carafe, then switch off and let stand for 1 hour.
• Restart the coffee machine to complete the cycle.
• Rinse the coffee machine by running it through 2 full cylces with water only.
• On the timer models if the display continues to read “CALC“ repeat the process again.
I understand you cant activate the machine at the moment to descale but if you use the white vinegar solution it may free somthing up in the water resivour. The problem sounds like a stuck water level sensor, if you can see if you can locate and free up this sensor.
Hope this info helps.
Posted on May 25, 2009
  • 15,935 Answers
CLICK HERE for your Manual
if the "gibberish looks like this...
b==d
the water sensor has failed.
It thinks there is no water in the reservoir.
Have you de-scaled the unit lately? the sensor may just be scaled up.
Thanks for using FixYa
  • 749 Answers
Hi, can you give me the full make/model?
Posted on May 23, 2009
  • Muzzammil Ishfaq
    Muzzammil Ishfaq May 23, 2009
    what error code does it show? 06? or 6?
    Brigadier General:
  • 8,619 Answers
Hi
2 Series of Three beeps tells you that the coffee is ready. However, if it beeps on regular basis then you'll need to reprogram your timer. And, if reprogramming doesn't help the probably a fault in microcontroller control board of the coffee maker.
Also see this link for the manual to see how to reprogram the coffee maker--
Krups Coffee Maker
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 22, 2009
  • Rylee Smith
    Rylee Smith May 23, 2009
    Hi
    You need to programme your coffee machine as per the procedure given below:
    • Plug in your appliance: the display will light up briefly in blue, blink “8888“ and then remain fixed.
    • Press the O/I button if you wish to make coffee without using the programmable mode.
    • The display will light up in blue and alternately show “ON“ and the current time.
    • Press the O/I button to shut off the coffee machine. The display will no longer be lit.
    Setting and Adjusting the Clock
    • The machine must be “off“.
    • Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
    • Adjust the hours in steps by pressing the h/min button (n).
    • Press the prog button : the minutes will blink“ XX 88“.
    • Adjust the minutes in steps by pressing the h/min button.
    • Confirm the setting by pressing the prog button.
    Setting Auto On
    This programs the coffee machine to start automatically at the set time each day.
    • Press the prog button (o) briefly : the display will blink “prog“ for about 1 second, followed by “8888“.
    • Press the prog button briefly: the hours will blink “88 _ _“.
    • Press the prog button briefly: the minutes will blink “XX 88“.
    • Adjust the minutes in steps by pressing the h/min button .
    • Confirm the setting by pressing the prog button briefly:
    • The display (q) will show the time and a “ “.
    • Press the h/min button to cancel the programming.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
Krups coffee maker constantly beeping, even when no water or not turned on, when making coffee it beeps turns off then beeps and turns on - getting to the point of just unplugging to stop beeping.
Hello Linda Foster,
If there is NOT an OWNERS MANUAL immediately
available.. there are a huge selection of KRUPPS
machines...
Chose from the attached list...
Find the trouble section... Read & heed
Results for krupps coffee maker var myCallback function document ready...
Hope this helps...
(or REPOST with model number for BETTER QUALITY answers).
Carnac the Magnificent
Oct 25, 2017 | Krups Coffee Makers & Espresso Machines
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
Krups kt406
http://www.ereplacementparts.com/krups-kt4065505ca-dahlstrom-therm-timer-coffee-maker-parts-c-144838_144839_300018.html
Replacement parts! Search the website for your exact model. Mine was the kt406550 /5ca. You can find it on the bottom of the machine.
Feb 16, 2012 | Coffee Makers & Espresso Machines
Flashing 8888 will not make coffee
I had a similar problem. It stopped working mid-brew, then flashed 8888 incessantly and I couldn't get anything to respond. I unplugged, turned it upside down overnight to drain. Next day it worked fine and has been OK since.
Aug 08, 2009 | Krups FME2 Coffee Maker
Error keeps popping up
PROBLEM
CAUSE
SOLUTION
3 beeps sound and E:rr flashes on LCD display (31)
prog (24) was pressed before clock time was set
auto (23) was pressed while no program was stored
TSB was pressed (25) before brew cycle was complete
Set clock time, then set the program
Set the program first.
Wait until brew cycle is complete and 2 beeps sound
Mar 05, 2009 | GE 106591 Coffee Maker
Clock shorted out
Hi George here is solution I posted for another person:
you need to replace circuit board that has timer and auto shut-off I have same problem krups doesn't think it is a safety issue because the coffee maker has a thermal switch. But I still think it is. Also if you are not carefull when you fill with water it will steem back in your face!
SmallAppliance.com has special order replacement boards.
I will be replacing mine
Mar 05, 2009 | Krups Aroma Control 229 Coffee Maker
Setting the clock on my coffee maker
After turning the coffee maker on press and hold down the timer button until flashing; then press the hour and minute buttons to set the clock.
Dec 19, 2008 | Cook's Essentials Cooks Essentials Arome...
Coffee Makers & Espresso Machines Logo
383 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
