Question about Wagner SprayTech Wagner Airless Paint Spray Unit Project 115
Shoots drips Hi I have a PP117. Worked fine yesterday when I used it for the first time, priming a wooden wall with water based prime. Today when I sprayed the first layer of coat, water based paint. Most times when I pressed the trigged, it shoot some drips of paint onto the wall, on or a few each time. Why does this problem occur. Changing the pressure did not help. I am running at a pressure low enough just so I don't get those lines. Thanx, Thomas
  • 50 Answers
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Posted on May 29, 2014
Keurig special edition b60 prime problem? My keurig now has the prime message showing up. I have ran through all of keurigs trouble shooting and none of it has worked. The prime message will go away...
You may want to try this.
Simply trying to clear the lines often will work. And as you will see from the many comments below, by far the most reliable way to get your Keurig brewer working again is the "Slap and Burp" method.
Here is how you do it.
First, unplug the brewer and remove both the water reservoir and drip tray.
Next, hold the brewer upside down over the sink and slap the base a few times. And I mean really slap it.
Now put everything back together and try brewing again. Most of the time this works with a couple of good slaps. If not, try it again.
And don't worry, there are no laws against giving your Keurig a good slapping!
Apr 21, 2013 | Coffee Makers & Espresso Machines
I have twin 135 hp Yamaha outboard engines. Neither engine will start when cold.Putting small amount of gas into air intake and engine starts, engine starts fine when hot. Choke solenoid working
just like a car before the car start the fuel pump shoots gas in the carb or a lawnmower you gotta prime it all the gas that was in the carbs when you shut them motors off has done evaporated check your fuel cells see if there is a hand pump to prime the carbs unless its electric fuel pumps either way them carbs have to be primed
Dec 22, 2012 | Motorcycles
Hi I have bought a 1985 700 maxim watercooled it has been sitting for appr 2 years today I took carbs out, disassembled them, cleaned them w carb cleaner and put them back in in addition to that I...
If I understand "the petcock was in prime position and it eventually quit dripping."
Prime = on
Sound like the needle rubber was hard and after a while they soften up enough to cut off the fuel.
Keep an eye on it and ride safe.
Ken
Feb 02, 2011 | 1985 Yamaha XJ 700 X Maxim
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Pump worked yesterday but would not shut off. I left pressure in system over night, today pressure gone, when I turn pump on, the motor runs, but no pressure or water pumped.
1.Turn off the power going to the pump.
2.Drain all the water inside the pressure tank.
3.Open the priming port plug of the pump, and fill it
full with water.
4. Put the priming port plug back in place. Close the
flow control valve and start the pump.
5. Slowly open the flow control valve to 1/8 to 1/4
open and see the flow stabilize at 20 psi of the
pressure gauge.
Hope this will help.
Nov 20, 2009 | Plumbing
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
My Hayward 2 hp pump basket water level drops to about half after the pump turns off. Is there an air leak? No water shoots out when pump is running. Will this damage my pump?
Yes, there is an air leak somewhere.
Only if you are using a timer and the pump fails to prime when the timer turns it on and it runs a long time in that condition. If someone turns it on, be sure it primes and you are fine.
Jul 04, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Wont start
Try this sequence. Pump up the fuel bulb until it gets hard. There should be something equvilent to a fast idle setting, then hold in the primer(electric choke) and finally turn the key and crank. When it tries to start go easy on the electric choke. You may want to see if the electric choke moves freely.
Mar 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Wagner SprayTech Wagner Airless Paint Spray Unit Project 115 Logo
244 people viewed this question
Top Wagner SprayTech Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Wagner SprayTech Tool and Hardware - Other Expert? Answer questions, earn points and help others
