Question about Hoover H130E Front Load Washer
Vision hd 8kg model vhd 842 80
Wont take in water have changed solenoid valve,checked all hoses,there is power getting to machine,but door security light keeps flashing..
4 Suggested Answers
SOURCE: hoover HD Vision 8kg washing machine, wont stop
UNPLUG IT
Posted on Dec 27, 2009
kapishtech
  • 2272 Answers
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
Posted on Sep 18, 2010
SOURCE: After a power cut my washer wont work the door
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Posted on Apr 29, 2011
Hoover vision hd 8kg door security button flashing
i now have same problem- did you get a solution?
Feb 17, 2012 | Hoover Washing Machines
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Apr 24, 2011 | Hoover Washing Machines
When doing a load and selecting Cold/Cold temps, I am only getting HOT water. All the temp settings are only allowing HOT water to flow. I have a Whirlpool GHW9150PW0 model. Anyone know why this is?
The cold part of the water inlet/mixing valve assembly (part #8181694) is not working. Disconnect power to the machine then remove the three screws at the back of the top panel securing it to the cabinet. Once the screws are removed, slide the top panel to the back of the machine then lift it off.
Check the valve solenoids using an ohmmeter. Disconnect a wire from each of the solenoids then measure the resistance between the terminals of each solenoid with the ohmmeter set to X100. The resistance of the solenoids must be almost identical at about 800 ohms.
Check the continuity of the solenoid wiring harness to the central control unit. Make sure the connector at the central control unit is properly seated to ensure good connection. The 4-wire valve solenoid connector is the fourth connector from the left (facing the front of the washer) of the central control unit.
Disconnect the solenoid wires from its terminals if the resistances of the solenoids found above are the same and there's a good connection between the solenoids and the central control unit. Cleaning the terminals will help. Reconnect the solenoid wires in place of the other solenoid wires, and then start a new cycle to check if the temperature of the water coming into the washer changes.
Replace the water inlet/mixing valve if one of the following is observed:
  1. The resistances of the valve solenoids are not the same; one solenoid is open, and the connection between the solenoids and the central control unit is okay.
  2. The water temperature does not change after the hot and cold solenoid wires are interchanged.
Remove the fill hoses then remove the valve assembly mounting screws. Disconnect the valve assembly outlet hose then remove the valve assembly from the cabinet. Connect the outlet hose to the new valve assembly then mount it into position in the cabinet with the mounting screws.
Slide the top panel into position then secure it the three screws to the back of the machine.
Please let us know how this guide helped you or not so that we may know how it worked and how to improve it, if necessary.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
My dishwasher is full of water when the program finishes
Assuming the pump is working...
Is the outlet hose blocked, kinked, or plugged?
Does the machine drain after the wash cycle/before the rinse? If it does, the controller or timer is malfunctioning. If it doesn't, you need to check the drain valve and solenoid.
There is a solenoid that is supposed to move a valve to pump the water out of the machine at draining time. Either there is something stuck inside the valve that is preventing it from shifting, the solenoid/wiring is messed up, or the controller is bad.
Take the panel off the machine below the door. Find the drain hose. Follow that back to where it attaches to the dishwasher. The solenoid and valve is at/near where the hose attaches.
If there are no obstructions inside the valve you need to check the electric to the solenoid.
Run the machine and when it gets to the point that it should drain check to see if the solenoid has power to it. If it doesn't you have a wiring or controller problem.
If the solenoid has power, the solenoid itself is bad. Remove it and take it to your local appliance parts store along with the make and model of the dishwasher.
Dec 18, 2009 | Cars & Trucks
Problem with the flow rate to the entrance valves
Turn the water valves off and then unhook the water supply hoses from the machine. Look into the hole the hoses were connected to. Use a pliers to grab the tab on the filter screen(s) and pull them out of the water fill valve(s). Clean, reinstall, and reconnect hoses and turn valves back on. Most often you will find that the cold water supply is the culprit.
Feb 02, 2009 | LG WFT1071TP Top Load Washer
Hoover H130E Front Load Washer Logo
32 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
