Question about Pool & Spa
My hot tub drained overnight by itself will this have burn the motor up and could the garden hose being left in the tub have drained it that fast
  • 451 Answers
Most hot tubs have a low water cut off switch to protect the pump so it may be okay. A garden hose could have drained the water out overnight. Hope this helps.
Posted on Jan 03, 2014
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
I have a Roper RTW4340SQ0 washer that leaks profusely when it fills and throughout the washing cycles. I've checked the water valve and all the hoses associated with it as well as the pump and all the...
This model is direct drive with a front mounted drain pump. The drain pump is THE most common leak location on these type washers! The pumps do NOT generally leak at the hoses, but from the impeller side between the pump and motor. There will be a telltale water mark on motor side of the pump shell.It can easily be fixed by popping the 2 retaining clips, removing the two drain hoses, and pulling off the old plastic pump, replacing it in the reverse order after cleaning the end of the motor shaft. Pumps run about 30 dollars. If you are sure this isn't the culprit, check for signs of leakage between the tub center and transmission, there is a tub gasket there. The tub itself, is not likey to leak, it is one piece with heat welded seams.Go to Youtube and search Whirlpool washing machine repairs, there are a number of instructional videos that show you exactly how to repair these machines and save yourself a lot of money. Incidentally Roper is built by Whirlpool, that's why I said search with that name.
Hope this sheds some light on the problem
kcomp1863
Jan 19, 2011 | Roper RAX4233PQ Top Load Washer
How do you drain the spa?
There is probably a drain valve somewhere near the control panel ... forgetabout it ... too slow.
Best way is to get a small pump and pump it away. Next best is wet dry (shop vac). My favorite is siphon ... dont have to buy anything or drag anything out ... only a hose. By the time my water is out ... I have had time to do the necessary surface cleaning and waxing.
May 15, 2010 | Jandy AQUALINK RS TELELINK KIT
Water left in tub after wash cycle
Can you hear the water pump running when it is supposed to drain just before the spin cycle? If it doesn't, the pump motor may be bad or the pump itself may have blockage that stalls the motor. If it runs, but doesn't pump anything, look for pinched drain hoses, an internally blocked drain (a stray sock perhaps?) within the outer tub, or a plugged pump/loose impeller. Hope this helps!
Apr 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Where is the drain on the Aruba Majestic Hot tub? I have never drained the tub and would like to keep it empty for a few months before refilling
the drain is located on the very lower left corner of the tub. (lower left is decribed as where the control panel is at the top, look at the bottom to find the plug and insert a hose to keep the water flowing away from the tub.
Oct 10, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Washing machine wont drain out and is full of water wont go into a spin
If there is a drain issue, sometimes there is an obvious solution. Check the drain hose for any kinks, as well as checking any lint filters in or on the drain hose. Is there a lint sock on the end that's full? Perhaps the drain line itself is plugged. You will want to make sure that the house drain system is not backed up or plugged. Always make sure that the washer drain hose is above the level of water in the drain tub. Some Whirlpool washers make use of a side-check valve near the tub outlet which may get clogged. A standpipe should be at least 1 1/4 inches in diameter, and never seal a drain hose into a standpipe. This can lead to back-siphoning. You also want to make sure that the standpipe is less than 96 inches in height. Pump problems show various symptoms. Sometimes the pump will lock up and seize. If the motor is running, it will continue to try to turn the pump. In the case of belt-driven pumps, the belt may break or burn through. The pulley may shear off. If there is enough tension on the belt, and the motor continues to try to turn it, you may wind up with a seized motor as well. The pump itself may have seized bearings, be jammed by clothing or another object; or the impeller blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the hoses. Look inside the hoses and see if there are any obstructions. Feel around inside the pump inlets for anything that may be jamming the pump itself. You can also use long-nosed pliers to feel around inside the pump for any items that may be causing a jam. If you haven't found a jam, and you still believe there may be a jam in the pump, you can completely remove the pump from the washer and inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part may go bad. Some older washer models have an electric-mechanical shifter. If it won't shift, it's best to call a professional appliance repair person to address this issue. If your transmission is leaking oil, there are really only two options at this point, either run it until it dies completely, or replace it now.
Sep 23, 2008 | Whirlpool Washing Machines
Tub in washer empties as fast as the water runs into tub
ck height of drain needs to be at least 30-36 inches from floor also be sure drain hose is only 6-8 inches into standpipe be sure there is a small air gap between drain hose and standpipe.. hose needs to fit loosely into standpipe or siphoning may occur
Aug 25, 2008 | Frigidaire GLET1031 Top Load Stacked...
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Kenmore 42990 front loading washer
If this is a 417 model your problem might be the pump itself. There is a pressure switch that detects whether or not there is any water left in the tub. If so, it will not go into high spin. Remove the lower panel and check the pump on the lower right side. See if there is any gunk or coins in there by removing the hoses attached to it. Have a flat pan or a bunch of towells ready to catch the remaining water from the tub. If the pump checks ok, the next move would be to check the motor controller itself.
Apr 25, 2006 | Kenmore 44921 Front Load Washer
Pool & Spa Logo
112 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
