Question about Troy-Bilt Storm 2840 277cc 28-in Two-Stage Gas Snow Blower 31AH64Q4711
Blades won't spin
Auger housing spins but the augers don't rotate. it was working, but I hit something
    Sergeant:
  • 416 Answers
Gear case is shot
Posted on Dec 30, 2014
The auger is no longer turning. How do I fix it?
Check for broken shear bolts first. Then, move on and check the auger belt. Finally, if all those are ok, check the gear housing on the auger drive shaft (right in front, between the two auger blades).
Feb 02, 2016 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
I have an older traeger and it doesnt seem to heat up on high mode. it has 2 fans and both work but one seems to knock now and again. when i cook chicken on high it will take 2 hours to cook.
The Traeger website at http://www.traegergrills.com/ has an FAQ about grills not reaching the appropriate temperature and how to adjust the augur to fix the problem. Here's what they say:
Q. I've been noticing that my grill temperature keeps dropping lower. What is the problem?
A. You need to "true" your auger. To do this:
  1. Run the unit out of pellets.
  2. Remove the allen screw and nut out of the auger and motor shaft.
  3. Try spinning the auger shaft over the motor shaft. The auger shaft should spin freely over the motor shaft without binding.
  4. If the auger binds, loosen the 7/16th inch bolts on the motor bracket and move bracket until you can rotate the auger shaft over the motor shaft. Then re-tighten 7/16th inch bolts. Make sure auger shaft still rotates over motor shaft, or repeat step 4 again until it does.
  5. Reattach auger and motor shafts using the screw and nut which you removed in step 2.
Hope this helps
Hope this helps
Jun 11, 2014 | Traeger Industries Grilling
Treager BBQ will not get hot at all.
Ensure your fire box is cleaned out and ventilation holes at the base are not obstructed. Ensure the induction fan is operating and moving air into the fire box.
According to Treager FAQ:
"I've been noticing that my grill temperature keeps dropping lower. What is the problem?
Reattach auger and motor shafts using the screw and nut which you removed in step 2."
Mar 05, 2014 | Traeger Industries BBQ070 All-in-One Grill...
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
Auger blades are spinning
sound like you might have 2 problems. If auger doesn't engage in heavy snow you probably just have ice accumulation inside the impeller. Dont try to engage until impeller is cleared of snow (shut off and unplug spark plug before cleaning) Second if blades are spinning than you must have hit something in your path and broke the shear bolt (about 2 bucks at hardware shop) remove the old bolt and replace it and it should work again if this is the problem. Good luck.
Feb 05, 2014 | Yard Machines Garden
I lose power and stall when i engage clutch to spin snowthrowing blades on my mtd 24" two stage snowblower. any way to fix?
You probably have a small rock or stick jammed in the smaller throwing auger. Carefully rotate the small auger backwards using a stick/board and tapping with a light hammer till the jamming object pops out. Be careful not to place your hands or fingers in even if it is not running. Worst case scenario the worm gear that rotates the larger auger is broken and jammed and needs replacement. If both augers move freely then you will have to remove the cover under the motor and inspect the belt drive mechanism.
Feb 21, 2011 | Mtd Products Yard Machines 158CC Tiller
The 2 rotating parts in the front that the snow is sucked into the machine, only half of it is rotating the other is not moving at all this causes the snow to pile up in front. whats missing or broke?
There is a shear pin that is broken.it looks like a bolt that is designed too break if you hit something that is hard and won,t break up.while it is not running rotate the side of the auger that is not turning untill the holes in the auger and the shaft line up then put new shear pin through auger and shaft.
Dec 27, 2010 | Garden
Auger blades won't turn
You need what they call a "friction wheel" replaced.
Oct 31, 2009 | Garden
Troy-Bilt Storm 2840 277cc 28-in Two-Stage Gas Snow Blower 31AH64Q4711 Logo
154 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
