Dryer Quit I have a maytag Dryer that quit on me. When you press the start button you hear a slight noise but doesn't do anything and in the inside you can smell burning through the vent. The Dryer is 7 years old and I've never had a problem with it before. What could this be and what am I looking at as far as price. my e-mail address is deliawalker@letu.edu 972.302.2129 cell
  • terry23 Jan 17, 2008
    dryer will not spin, and burning smell inside
SOURCE: maytag performa dryer vent got clogged and quit working
maytag performa dryer quit in middle of drying.
Posted on Dec 31, 2008
sclarke7
  • 222 Answers
SOURCE: Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Posted on Apr 07, 2009
  • 3 Answers
SOURCE: water will not drain, will not do anything.
I would check the lid switch. That is most likely the problem.
Posted on May 01, 2009
SOURCE: I have a Maytag washing machine approximately 6
Already signed up for the premium plan..got the answer.
thanks
Posted on Nov 02, 2009
  • 3 Answers
SOURCE: Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Posted on Feb 26, 2010
I have a Maytag LDE9304ACM dryer. It suddently quit today. When I press the start button, the start button light "lights up", but there is not sound and no rotation. I can hear the timer. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2011 | Maytag Dryers
Dryer won't start. Press the start button and it just makes a buzzing noise.
Is it growling at you? That is a sign of dry bearings. You can sometimes bring em back with a little lubrication. I wrote about it and posted some photos Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 17, 2011 | Dryers
My Maytag Performa Model # PYE4500AYW has quit. I press the start button and it won't start.
heatman101
Jun 27, 2011 | Maytag Dryers
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer stated when i push start button, then stop aft 10 mi
Hi, OK let me help. Do you hear any noise coming from the timer?
Whe it quit the first time, did it start right away or did you have to wait for a bit to restart it?
Vic
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 | Dryers
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Maytag Neptune Dryer humming but not running
This sounds like the motor is siezed or burned out. I wish I knew how much a motor is, but the Neptune is a good dryer so it would probably be worth it to get a new motor if indeed that's the problem.
Jan 21, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Open Questions:
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
