No programs will start
The dishwasher buttons have stopped working. There is definitely power to it and it was working fine yesterday! There are two programme lights lit at the same time (should only be one) and neither the programme select button, start button, or half load button are doing anything. I have tried turning the machine off at the owner supply and leaving it for half and hour to reset it but it still has the same problem. Please help!
  • 159 Answers
SOURCE: Machine won't activate
well I never heard of that brand so because you said a new flat Im guessing your form England. Good luck with the move. Ok I belive your problem is possibly the main control bord is bad.what you describe sounds like it. the only way to rest it it would be to replace the bord. doing that it should function normally. Good luck.
Posted on Aug 22, 2007
  • 40 Answers
SOURCE: Kitchenaid 24" SS dishwasher
the first thing to check is power. check your breakers to see if any are tripped. if so turn it off than on some breakers do not reset if you just switch them to the on position. also check if it has a plug or shut off switch in a cabinet nearby .
Posted on Dec 31, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
SOURCE: error code 6502 on MP510
why error 6502..........?????
Help me pls.........!!!!!!!!!!!
Posted on Jun 12, 2008
Benimur
  • 6966 Answers
SOURCE: WASHER WON'T START
For some unknown reason(s) the Live Session/Chat window closed. I hope that the two buttons resolve the issue, otherwise, pls click on "Ask Me" for a follow-up solution.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 05, 2008
Will not run? Doing laundry yesterday an it stopped in middle of cycle. Now when I push start button it clicks but will not start. The lights all work so it has power. What is wrong?
turn the breaker off which should be in your furnace room.
Wait a few minutes and turn it back on. It will reset the computer in your machine and it should work just fine then. This also works on dishwashers.
Jul 08, 2015 | Dryers
Our 3 month old ge adora dishwasher stopped working properly yesterday. Made funny noise and later I started smelling something burning. Opened it and noticed no water was in it. Restarted and still n
Sounds like the water inlet valve isn't working. Check your house water pressure and make sure it's not above 80 psi. If it isn't, then call a repair company that handles GE warranty work.
Dec 02, 2014 | GE Adora Dishwasher. Built-In Tall Tub...
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
Maytag MDBtt60awb will not start. Power definitely at dishwasher as panel lights are on, however "start" button does nothing. Dishwasher is less than 2 years old. The panel buttons eventually turn off. ...
most likely you have a bad motor when replacing the motor ihave found it is cheaper to get the pump with the motor attached where as they charge you more money for just the motor or the pump seprately try allbrands appliance parts they seem to be cheaper
Apr 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
No Power
You probably have a bad door switch assm, there is no reset on this unit, if you have a bad door switch the unit thinks the door is open so it won't start.
Jul 15, 2008 | Whirlpool 24 in. DU900PCD Built-in...
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Dec 31, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
jasbo
jasbo
