Question about Toshiba Portege R400-S4831 - Core Duo U2500 1.2 GHz - 12.1in. TFT (S6478886) PC Notebook
Fan noise loud and always present
The fan is on all the time, and is very noisy. It has nothing to do with CPU usage, and I even reformatted it, to no avail, noise still very present. I cant remember if it has always been this noisy, but I can't believe this is the normal noise level!
    Top Expert:
  • Toshiba Master
  • 25,306 Answers
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Posted on Jan 03, 2014
My PC's Fan has a loud humming sound every time I boot up PC, how do I fix that?
Hi.
As Dean said, if the humming noise is always present even with the fan spinning at low RPM, replace it. If it's only loud when booting it might be normal ; some computer's BIOS spin the fan very fast when booting and when the Operating system or preset parameters take over, they gradually lower the speed. By the way, unplug the fans one at a time to find which one is causing the noise. If it is a case fan they cost only a few bucks, if it is the CPU fan it is a bit more expensive but aftermarket cooler can be found for around 20$. If you need to replace the CPU cooler, make sure you clean the old thermal paste and apply some fresh one. For a tutorial how Youtube is your best friends ;)
Nov 22, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Loud fan noise on desktop pc
Could be the case fan or the CPU fan. Open the case and determine which fan is noisy by unplugging them one at a time. Replace the bad fan with a new one and you are good.
Apr 16, 2014 | Compaq Presario Fan
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
LOUD cooling fan noise comes and goes...usually when downloading and sometimes when just sitting unused. have cleaned it completely ...someone said possible fan drivers or heatsink (colling fins are...
Some fans are automatically temperature-controlled -- they speed up, and, of course, make more noise, as the temperature rises.
Background tasks, such as Windows Automatic Update and scheduled virus-scans, can cause the computer to become "busy" when otherwise "sitting unused".
Next time the noise increases, enter CTRL-ALT-DELETE and open "Task Manager", and click the "Performance" tab, to see if the CPU-usage is reaching 100%. Click the "Processes" tab, and then click on the 'CPU' column-heading, and click it a SECOND time, so that Windows lists the "top" consumers of CPU at the top of the list of processes. Which process is consuming the majority of the CPU?
Oct 26, 2009 | Computers & Internet
My sony vaio VGN-CS11S is soo noisy
The fan's bearings are probably going bad, or there may be some object that was sucked in to cause the noise.
Sep 28, 2009 | Sony CPU FAN CPU Fan
CPU fan issues
The fan may not stay on all the time - its a feature of laptops to help save power. The fan is also variable speed. As the CPU gets hotter, the fan speeds up. When the CPU isn't being used as much and is cooler, the fan slows or even stops. It turns on to full speed when you first turn the laptop on as part of the BIOS system check.
The noise is another issue. You could have a broken "fin" or fan blade. The bearing could be going out. Something may have simply "crawled" inside the fan's output vent. In any case it may be worth your time to have a professional open up the laptop and look at the fan. I have heard a LOT of noisy laptop fans in my day, and believe me it's not the worst thing to put up with.
Mar 19, 2009 | IBM ThinkPad T42 Notebook
Cpu makes noise when play game
blown any dust out of the back of the pc?
hope i was helpfull
good luck
Mar 18, 2009 | HP Compaq d530 SFF PC Desktop
My cpu fan will not shut off it is so loud should i replace the fan or is there a way to repair this problem
Your CPU fan should always be on while the computer is on. If it's off, your computer is going to crach in a matter of time. The noise is normal. If it's to loud, replace the fan. Nothing major. But it is normal for the fan to be loud. Thats a good sign it's cooling the CPU. But you can get a shfter 1. Your computer might over heat though. Good luck.
Mar 05, 2009 | eMachines T5048 PC Desktop
Hp laptop dv9500 noisy and loud fan ...
The sound you are hearing is probably the fan, This fan has a noisy bearing and will eventually lock up and the fan will stop spinning and therefore the CPU will overheat and shutdown.
The fan needs to be replaced.
Feb 13, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Noisy machine
very likely it is the power supply fan. I also had a noisy fan and replacing it was a solution. try to get the measurement for the screw mounting dimensions and the height (thickness) and also the driving voltage then search ebay's site. it can be cleaned and lubricated however...
Sep 16, 2007 | E-Machines eMachines Desktop PC
Toshiba Portege R400-S4831 - Core Duo U2500 1.2 GHz - 12.1in. TFT (S6478886) PC Notebook Logo
80 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
