Question about Maxi-Cosi Baby Gear
Maxi Cosi Pria 70 ****** strap too tight
My son is almost 3 years old. Facing forward position. ****** strap already in the farthest out position. It seems very tight. Help!
    New Friend:
  • 63 Answers
Make sure your son does not exceed the weight limits for the forward facing harness. Do not put your child in the harness wearing bulky clothing, but use a blanket or poncho in the car instead of a snowsuit or winter coat.
Posted on Mar 05, 2014
4 Suggested Answers
  • 419 Answers
SOURCE: Maxi-Cosi central tension strap has been pulled out
I would always suggest that you take this back to the retailer to have the part professionally repaired, or contact www.maxi-cosi.com who will be able to advise you.
I hope this helps.
Posted on Sep 15, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 419 Answers
SOURCE: I need a replacement maxi cosi cabriofix crotch
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Posted on Nov 29, 2009
Maxi Cosi Pria 70 strap too tight
Please contact Dorel USA direct with your enquiry
Jan 03, 2014 | Maxi-Cosi Baby Gear
How do i install it facing forward?
Hi
This is not a UK product so we're unable to advise on it. What country are you in? We can provide contact details for the relevant customer care team who can help.
Mar 12, 2013 | Safety 1st Alpha Omega Elite 22456 TTN...
Hello, I have a Lumix Panasonic DMC-FX9 and I turned it on today and the screen reads "THIS MEMORY CARD IS PROTECTED" I cannot take pictures nor can I change the screen. It seems to be locked....
Take a look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 04, 2010 | Cameras
How do you install and know if its reclined. my son seems to be sitting too upright, he is only 6 months but already 21 pounds. he is appropriate weight wise. I have a 2006 explorer.
u could use the safety straps on the back. or you could run the seatbelt through the holes at the bottom of the car seat. check your users manual from your explorer to see where the safety hooks are. http://www.eddiebauer.djgusa.com/usa/eng/Instructions?ProductNumber=22790WPR
Jan 13, 2010 | Eddie Bauer 3-In-1 with Latch
I hope this helps.
Jun 14, 2009 | Baby Gear
How to loosen the straps on envenflo tribute carseat?
This is about all I could find for you. Hope it helps.
Had one - its a huge pain in the **** and I always busted my fingernails doing it. The metal clips have to slide over the bumps to get them out. I hated that thing. May I make a suggestion? Return it. lol . I'm figuring you got a combo seat - Evenflo Generations, Bolero, Chase, that is a forward facing only seat to 40lbs, or a convertible seat like Evenflo Tribute that is forward facing to 40lbs. Since I don't know her age its hard to make a suggestion, but for just a little more money (we paid $79 for our Chase) you could get a much better seat. If she needs a convertible that will rear face, get the Evenflo Triumph for $150 or less, The Evenflo Triumph Advance (not the original Triumph, make sure it says Advance) is a great seat. $150 version at Babies R Us has padding similar to Britax seats, top slots of 17", harnesses to 35lbs rear facing, and 50lbs forward facing. $120 Walmart version just has little less plush padding. Wide open belt path, easy to install, though it doesn't have built in lockoffs. The harness adjusts at the front of the car seat, you don't have to take the car seat out of the car just to raise/lower the straps. It's one of only 2 seats that does this (The Britax Boulevard is the other, I believE), and it has infinite harness adjustment so the harness always fits perfectly until its outgrown. No more tugging straps to tighten them either. You tighten and loosen the harness using knobs on the side of the seat. As a major bonus, it can be used in a recline position even in forward facing mode. Awesome for kids who still sleep in the car. I LOVE THIS SEAT! LOL My son, who is too big for every other car seat at Walmart has the same amount of room in this as the Britax Marathon.
If she is forward facing (over 30lbs and over 2years old) then a Graco Nautilus would be a lot easier to use and install, $150. Harnesses to 65lbs and then becomes a booster, will be the last seat you have to buy her. Metal reinforced.
Combo seats are usually a major waste of money, as they only harness to 40lbs, no more than most convertible car seats, so you're really not getting any more use out them then the convertible seat.
Jun 12, 2009 | Evenflo Generations
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Rear seat single latch
The latch that is on the top is called the tether strap. It is only used in the forward facing position.
Jul 06, 2008 | Eddie Bauer 3-In-1 with Latch
Purple legs
Which way is she facing? I have a 9 month old baby boy and this doesn't happen, and he is a little hefty! I am wondering if your lower straps are too tight. If she is facing forward, does she lean forward having the material cut into her legs? Maybe that causes the circulation loss. I always have my son face inward. He likes it more and it is more natural.
Jun 30, 2008 | Baby Bjorn Active Baby Carrier
Baby Gear Logo
95 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
