Question about Funai Televison & Video
Funai hdmi not working
I hook up the HDMI from Funai DVD player to TV HDMI input. Sound but no picture. Cables OK. Worked with Laptop.
SOURCE: No video throught HDMI output
press set up go option number 1 then go hdmi monitor and input yes. then press set up again
Posted on Dec 11, 2007
  • 208 Answers
SOURCE: hdmi input not working
Sounds like a failure on the main or av pwb in the TV. Do you have another component such as sat. rec or cable box to try with hdmi?
Posted on Feb 05, 2008
micromaster
  • 3614 Answers
SOURCE: PS3 been working fine over
TV Connectivity
The issue of connectivity between the PS3 and the display is very complex and depends on the type of TV (Analog, Digital or HD Ready), the maker of TV (until recently, only Toshiba TVs have component AV connections as standard in Europe, most other Euro TV sets use SCART which can not carry an HD signal) and specification of TV (the very latest HD Ready TV sets have wider connectivity options than earlier HD "capable" TVs from the same manufacturer which may have lacked HDMI), and finally the configuration of the PS3 model purchased.
Posted on Feb 18, 2008
  • 76 Answers
SOURCE: No Sound
possibly the sound part of the DVD player went out it happens all the time but to get it fixed you have to take it to a repair shop. Hope this helps =)
Posted on Feb 25, 2008
  • 306 Answers
SOURCE: HDMI to DVI gives pink screen
Make sure the Geforce outputs in DVI-digital
then  Boot the PC while the TV is on and connected. This allows the card to read the EDID from the TV and provide the best resolution...
Most displays work best at their native resolution, which is either 1920 x 1080, 1280 x 720, or 1024 x 768 for most HD TVs. It sounds like your video card has difficulty handling resolutions that high and that may be your problem.
One has to remember that DVI/HDMI is capable of carrying two types of Colourspaces: RGB and YPrPb. Unless modified, the PC will always output RGB.
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem,  Make sure the Geforce outputs in DVI-digital
Do you any other components that use HDMI that you can test, or another HDMI port on your TV that you can use? If not, then the best you can do is swap the cable and contact your provider about the problem, as well as contact toshiba if swapping the cable and box doesn't resolve the color problem.
Posted on Oct 17, 2008
Hi, I have a Funai vhs dvd combo recorder model drv-b2737 and would like to know how I can set this up with my flat screen tv and what cables would I need to accomplish this. Thank you
This has no HDMI socket so you have a choice of either SCART or SVHS depending on what your TV has. If the TV users HDMI you might want to consider a SCART to HDMI adapter lead.
http://www.ebuyer.com/133106-startech-com-6-ft-hdmi-to-dvi-d-cable-m-m-hdmidvimm6?mkwid=sWA3N2WiH_dc&pcrid=51630194939&pkw=&pmt=&gclid=Cj0KEQiAyuPCBRCimuayhb3qqvwBEiQAgz62kTtKa_YG_1esIQiPgik-Xm5AFxuGZI25r11jA5KJOFwaAjJj8P8HAQ
Plug the SCART to TV in the bottom SCART not the top one!
If you just want a SCART to SCART make certain you get the highest quality ones you can find.
There is an OPTICAL output for the high quality sound. You can connect this via an OPTICAL lead to either a Surround Sound unit if you have one or direct to the TV. Again if it has an OPITICAL lead.
If using make certain the output it is switched on at both ends. You will see a red light if the TV is outputting it, with it unconnected to the VCR.
Dec 20, 2016 | Funai Televison & Video
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Funai tv 32 inch LED
what are you using with hdmi? if you are using a laptop you must go to your speaker configuration and change it
Dec 02, 2013 | Panasonic Televison & Video
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Televison & Video Logo
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
