Question about Indesit Dishwashers
How to preheat an indesit oven?
I want to bake a ake but dont know how to preheat the oven and nothing is there in the manual that can help me.
Krazytech
  • 725 Answers
SOURCE: GE modelJBP65G V2AD hitchen range
it sounds like your TO8 CONTROL it is you oven controls and clock. let me know if you want to replace it ..
Posted on Aug 25, 2007
  • 56 Answers
SOURCE: Oven Wont Preheat
does the bottom element get hot? could be a bad heating element.
Posted on Feb 01, 2009
  • 8 Answers
SOURCE: Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Posted on Jun 24, 2009
SOURCE: Caloric Heritage Series oven has no preheat achieved indicator
my doesn't have a light, I just wait about twenty minutes and assume it's up to temp. glass door hasn't exploded yet...
Posted on Oct 03, 2009
  • 180 Answers
SOURCE: The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Posted on Jan 30, 2011
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
I hit the bake button on my oven and after 10 secs it says preheat and thats all that happens nothing else no heat at all
Your oven will continue to indicate that it is preheat mode until the thermostat senses the proper set temperature. If you are getting no heat then you will need to address that issue. This could be many things but the most notorious would be the heating element. Could be the control panel as well. Some ovens have a knob for preheat, bake and clean with a separate knob to adjust the temperature. Make sure both are set properly.
Regards, Tony
Apr 07, 2011 | Kenmore Ovens
I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
I hope this helps.
Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Preheat takes too long
does the oven bake properly when it does reach temps?
if this is a newer oven, with a hidden bake element, they do take longer to preheat so may not have any problems, just give it about 15 minutes to preheat.
if it is older and doesnt bake right, then you may have a bad bake element.
the unit will heat but wont bake right.
unplug the oven and take the bake element to your local parts house, they can check it and sell you a new one if needed.
Jan 10, 2010 | Frigidaire Ovens
F2=overheat
Mar 23, 2009 | Kenmore Ovens
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
Aug 24, 2007 | GE JBP65 Electric Kitchen Range
Dishwashers Logo
78 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
