1997 Honda CR-V Logo
Joufis J Posted on Jan 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1997 honda crv. wont start
Engine turns off while driving, ignition ok, sparks ok, injector ok, fuel ok, battery ok, starter ok...help me
_-__-___-_
Level 3:
  • Honda Master 20,706 Answers
  • Posted on Jan 04, 2014
_-__-___-_
Honda Master
Level 3:
Answers
20706
Questions
Helped
6803982
Points
57965
Which engine??????????????????
one of those is false. i bet. ever the the 60k mile tune up this decade ? Yes, good, no?, well, what did you expect?
driving honda's top death is just that....see end. below.
my guess is you are doing one test wrong. , (i cant see you, so...)
THE ROPES: (called basics ) order counts big time.
1-good engine? (compression at 150psi or more x4? or x6 if V6.
2-good spark at all cyl. and timing right. check timing.
if timing of spark is way off the cam belt slipped, no service ever done is cause.
3-good fueling, it runs. (if not flooded (is it) test fuel does work here.
in this step.
turns off driving, but how did you do that, if it wont start?????
my guess is the stalls were the preamble to the end death
exceptions, to above. ( 1st CAT ,is rare)
1: CAT melted. (there is a cheap simple test ,ask)
2: ISC stuck closed, (Aka; iAC electric) use 10% throttle to mimic this bad part and car starts easy , this trick is in the operators manual.
3: EGR stuck wide open, see 10% above, trick. or clean it.
4: engine flooded, see opr. guide for WOT cranking
you crank at WOT. wide open throttle, and EFI cuts all fuel, clearing
the flood.
so, do you look at spark tips for BAD COLOR or soaking wet with fuel.
Look at them. (they speak volumes)
old spark plates and winter hate each other..
do the full tune up, filters ,cap rotor, wires and plugs. and magic happes, and if the timing belt is old, BOOM
the HONDA IS NOT FREE RUNNING at all.
that means ,skip belt service, a $25 belt can wreck the whole engine.
or at the least just bent valves,
on this engine, my cylinder leak down tool comes out 1st.
(your symptoms)
PLUGS LOOK LIKE THIS?
http://www.fixkick.com/fresh-air/sparks-flooded1a.jpg
3 Related Answers
Anonymous
  • Posted on Jun 21, 2008
SOURCE: 1997 honda civic wont start
your cat converter could b bad
Anonymous
  • Posted on Oct 03, 2008
SOURCE: 1997 Honda CRV - Engine just dies while driving down the road.
I had that same problem a while ago. I changed the coil and the ignition and I have had no problems since. Give that a try and see if it works. I have a 1997 honda crv myself and it seemed to work.
Anonymous
  • 958 Answers
  • Posted on Oct 20, 2008
SOURCE: 2005 Honda CRV won't start
if the clicking sound is coming from the engine compartment, it is the starter solenoid. let her try it a couple of times. sometimes it would connect and start the car. then she can bring it home.
tnx 4 using fixya,
drcool
2answers
98 Honda crv want crank had tune up done two weeks later it want crank was running good.
Make sure battery has a full charge. Cranking is starter motor action, meaning the starter motor is cranking the engine. If the starter motor won't crank the engine, then we need to test starter motor wiring circuits.
If it cranks good, but, won't start, have a helper crank it while you check for spark at the spark plugs, where applicable. If spark everywhere, use a gage and check proper fuel pressure and also, check for fuel injector pulse, engine cranking.
Can you check for applicable trouble codes?
I can only make suggestions, you have to do the testing. I give the same info to guys and gals, I don't know how to do it any other way.
Crv 1997 wont start after turns off while driving,,starter ok, ignition ok, spark ok, injector ok, fuel pump motor ok
Flywheel teeth may be missing ,wire connections at distributor coil or alternator Vacuum leak at intake throttle body make sure all the mounting bolts are tight Hope that Helps
Crv wont start, ignition ok, spark ok, injector ok,
wow Triple posted, do we get 4th?
still no engines size s stated, or if A/T or or M./T tranny. wow.
back up 1 ,2,3, i did answer in depth.
so if 3x ok ,then maybe engine is bad. huh.
if spark timing is way off, the ignored timing belt did slip
5min check with any timing, light, bingo , way off, cam is slipped
and now the valves are all bent and compression is zilch.
short version ,back up for longer.
98 crv won't start
Check compression and timing belt. If belt is ok and you have compression, check to see if you have a pulse at the injectors. You use a device called a NOID light (basically a light bulb that plugs into the injector plug. Unplug the injectors one by one and plug the light in then crank the engine. Light should blink on and off if the system is working properly. If not check for a bad crank sensor, blown injector fuse and wiring harness. Hope this helps.
My mitsubishi eclipse 95 gs wont start and theres no light on my dash bored it will cranck but wont start at all i need help asap
Since the engine cranks, the battery, starter motor/starter motor solenoid are most likely
good, so suspect everything else on the list. When you narrow it down, re-post with a
more specific question about that particular component, since 100s of components must operate
nearly perfectly for a vehicle to actually start.
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Battery Cable Connector -- Broken/Corroded/Loose.
4 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset (aka Spark Plug Wires) -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injectors -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer (inside fuel tank) -- Clogged or Dirty Fuel Pump Strainer.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC (faulty computer)
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor Cap -- Worn, Loose, Cracked, or Incorrectly Installed Distributor Cap.
21 Inspect Distributor Rotor -- Worn, Loose, Burnt contact surface
22 Test/Inspect Neutral Safety Switch -- Faulty Neutral Safety Switch
New fuel pump and still wont start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
2answers
Willnot start pulled starter bench tested ok
Check all cables to the starter and the ground or negative cable from the battery to the engine or frame. They get old and break down between the insulation and you wont get enough current to start the car
1helpful
2answers
Try to start the car, engine turns but wont start
start with the basics, does the fuel pump work, do you have spark, do you have injector signal, are the fuses good, lots of variables here
1helpful
3answers
Honda 97 crv engine turns off while driving, and hard to
, pull a plug wire and ground it to the engine body and check for spark. if spark then
check your fuel system pressure, fuel pump
2answers
Wont start turns over but no start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
