Question about Emerson Televison & Video
Screen goes off and on
I get perfect sound. But the picture will flicker off and on. Haven't had the thing 7 months. Right now I unplugged it and will plug it in a few hours later to see if that fixes it. This happened after a sudden power surge cut all the TVs (or really monitors) in the house off. I'm looking for the instruction manual to troubleshoot and to find out what TV it exactly is. All I know is that it is an Emerson.
  • 653 Answers
I don't believe that can be repaired on your own. Emerson (Funai Service Corporation) has a 90 day warrantee on labor and 1 year warrantee on parts. Contact them at:
http://www.emersonaudiovideo.com/support/contact.php
Posted on Jan 03, 2014
  • 65 Answers
SOURCE: Toshiba 47HL167's screen has gone Completely Black
I don't know if you guys are still looking for an answer but turn the TV on where you can here that something is actually playing on the TV then grab a flashlight and turn all the lights off. Get real close to the screen and shine the flashlight on the screen. Can you see something on the screen? If you can then there is a very good chance that one of the inverter boards are out. This could be the slave or the master. For the 47" I actually have the same issue and have ordered the master inverter board. For the 42" I have both the master and the slave board and they are both working. So for the person that has that issue on the 42" TV if you want a board for your TV email me at ced70@hotmail.com. For the one with the 47" flip a coin and order an inverter board for it either master or slave and try it. To determine which inverter board it is you would have to take the DC voltage across the start and then the end to see if you are getting any power. I hope this helps. By the way inverter boards usually run between 60-120 dollars each and the slave board on both these TV's are easy to install. The master is a little harder due to the power button board is in front of it and has to be removed first. Let me know if this helped.
Posted on Jun 20, 2009
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
SOURCE: proview rx 326 model 3200 tv sound but no picture
I just fixed my proview 3200 that doesn't have picture but with sound.
First, thanks for the tips I got from this forum. I checked the 24v from the power supply board and that's perfectly working fine. I then check the fuses in the Inverter board. There are 4 white fuses (2amp I guess, i cant remember) and 1 black fuse (1amp/76v just behind the wire connector going to the power supply board). The black fuse is the one that blown out on my tv. This fuse supplies power to the LM358A IC. I know its not right but I just solder a thin piece of wire to short circuit this fuse. I'm lazy to drive to RadioShack to find this fuse. :)
....and that worked beautifully. Check the picture attached for what I did.
Posted on Jun 22, 2009
  • 5 Answers
Most of you that are having problems,it has nothing to do with your screens themselves,but with the capacitors in the power supply,the caps,over heat and the tops pop out and the dry out and are no longer any good,a soldering iron,solder,and flux are really all that is needed to repair this problem,get good caps at radio shack,or equal location,pay attention to polarity on the two contacts on the bottom of the caps,replace all that are poped up
Posted on Jul 19, 2009
It's not because of a sleep timer or any other settings. I have a similar problem with my SONY Bravia and it started after only 7 months. Sony has sent technicians to my place, had the TV at their place etc but they say the problem doesn't appear at their service center so they can't fix it. (They've just updated the software (3 times) but that has not helped at all.) I say it's ******** and I will report them to the consumer organisation. They also said they had never heard of this problem before, and that is very interesting since I found about 100 webpages where the problem is reported...:-( Never buying a Sony again!!!!
Posted on Feb 12, 2010
Picture blinks on an off an has no sound how can this be fixed
TV pic blinks on/off when connected to satellite via hdmi - Forums ...
www.cnet.com > Forums > Sony
CNETApr 7, 2013 - We have a sony bravia LCD tv, model KDL-60EX500. ... The tv then started "blinking" on and off - no sound, black screen - for a half second or ... Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
LG TV : Picture not coming on screen, but TV is on.
Jul 14, 2014
How many have 'blinking' issue with Samsung led tv
Jan 26, 2011
More results from www.cnet.com
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
VIZIO flickering Tv screen easy fix( no money ) .... I left town unplugged the Tv. When I came home home ...
Jan 26, 2016 | Televison & Video
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Screen blinks and then goes out. tap on side and causes flickers
sure sounds like loose solder joints, look for them in the deflection circuit, just find the hard plastic encapsulated body with the thick red wire sticking out of it thats where usually the loose solder joints develop.
Sep 09, 2009 | Hitachi 50UX57B 50" Rear Projection...
My 14 month old, 32 inch Samsung flat screen tv ''flickers'' The cable went 'out' 3 or more times and when returning the TV started flickering. We have unplugged & plugged it back in several times, but...
Check if this occurs regardless what the source of the signal, whether it is DVD or cable or a playstation. You can also check if the Menu flickers as well. If the menu does not flicker along with the picture it could be a problem with the source, probably your with the cable box or the port where it goes to on your tv
Aug 05, 2009 | Televison & Video
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Screen goes crazy after about 1 minute
try it on tuner mode to seperate the fault from video to rf input,if gone the video pc board is at fault.
Aug 11, 2008 | Samsung HLN467W 46" Rear Projection HDTV
A340 screen flickers unexpectedly!
i would suggest taking batteries out overnight and letting the camera discharge the stored power. then trying it again. also make sure what mode your in because the shake warning makes certain lights flicker
Jun 14, 2007 | Fuji FinePix A340 Digital Camera
Televison & Video Logo
196 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
