Question about Health & Beauty
Southworth corner cutter repair
Clutch noise
Staples Shredder SPL-TXC22A makes a "clunking" noise during use. Noise diminished after feeding a couple of WD-40 soaked paper towels but noise returned. Fixable?just use it until it dies and replace?
probably find that some cutters have been damaged and are hitting each other rather than sliding past each other
using wd 40 is lubricating those cutters but as the lubricant is used by the new paper it becomes inefficient
get a quote for repairs but generally ( unless the machine cost is in the 4 figure area) it is not cost effective to repair
Nov 28, 2016 | Staples Office Equipment & Supplies
Ticking noise when driving and when in neutral just slightly touch cluth pedal and noise stops
Sounds like you have a clutch rod touching something under the cutter body. Touching the pedal and the noise stops tells me that you have put tension on the connecting rods and have removed it from touching whatever it is touching.
Dec 21, 2013 | Garden
Brother 1034d serger. Seems unusually noisy (mechanically) in needle/cutter area. Not motor or belt as noise is metal parts clacking even after new needles, cleaning, oiling. Is this sound normal for...
in response to all serger, no, after my babylock serger is cleaned and serviced it runs quietly.
as for the brother, it's possible thats normal, try contacting a repair shop in your area and tell them about the serger and see what they say.
it's possible that the serger may need some type of adjustment
or a part may have broken .
Sep 06, 2013 | Baby Lock Eclipse Serger
Engine run but don't turn
You're a bit vague in your problem description here, but I'm assuming you mean that when you give your machine gas that the cutting head will not turn. First I would check the cutter head to be sure that no trash has wound itself around the shaft preventing the head to turn...if that is not the problem turn the cutter head by hand and check to see that the bearing inside the cutter head has not seized, it should turn freely with no noise....if no joy check the cable which runs through the shaft from the engine to the cutter head it may be broken or frayed, also check to see that there are no problems with the clutch (broken springs, broken pads, or a broken key) that should do it ...hope this helps...;-D
Aug 09, 2010 | Ryobi Garden
Making a funny noise and not shaving well
8585 shaver gave higher tone and stopped cutting especially after a few days growth, even with new cutter and foil. Cutter wasn't pressing against the foil properly due to a bit of wear on the spring clip holding the cutter pin. Fixed with about 1cm of cigarette paper moistened and rolled into a 1-2mm ball. Stuffed that into cutter pin hole and rammed home with the cutter pin. Take the foil off and wiggle the cutter - if its feels loose, this might help, though the battery might just be getting old.
Jul 10, 2010 | Braun 8585 Electric Shaver
Starter cord not recoiling
To get to the starter rewind, you have to pull off the clutch hub and clutch. Without the proper tools, it would be best to take it to a shop. Dwain
May 26, 2009 | Poulan "Poulan" Pp325 17" Gas Brushcutter...
Error #80
I sounds like the cutter is jammed. This most likely was caused by a some tape getting caught in the cutter mechanism or by a build-up of adhesive on the cutter blades. The noise is most likely the cutter trying to actuate and not being able to. The solution is to clean the cutter to remove any debris and adhesive. This is normally done by a service technician and thus requires sending the printer to Brady. You can get faster service that costs less by having the printer cleaned by Graphic Products. They provide a full cleaning and diagnostic service, and can repair many problems. You can contact Graphic Products at 1-888-326-9244. They are also very nice about answering any questions you may have about the GlobalMark.
Oct 28, 2008 | Brady Globalmark MonoColor Label Printer
Health & Beauty Logo
49 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
