Question about Xerox ColorQube 8900X Solid Ink Multifunction Printer - Color - Plain
Error code 89-601.00
Jam code
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
Canon NP 6030 Error code E010
chiudere sportello superiore destro
Oct 04, 2007 | Office Equipment & Supplies
Xerox ColorQube 8900X Solid Ink Multifunction Printer - Color - Plain Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
