Question about Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9100LW1 noisy pump and tub spins only occasionally
Drain pump started making grating noises a few days ago, and occasionally refuses to spin during rinse cycle. Tub does spin properly during other cycles. Sometimes will get an F02 error, sometimes timer freezes at whatever time is left and does not advance, nor does the cycle.
Cleaned out the pump basket and found a quarter and a penny. Was unable to look into opening towards black colored motor, so unable to see if impeller is damaged or has foreign objects within. Basket itself was almost totally clean, with only a few long hairs caught in it along with the coins...little to no sludge on basket.
Removed gray corrugated hose from rear of machine and found thick gook at outlet near wall drain. Also found thick gook inside the elbow at the rear of machine, where hose attaches (strange that no gook in hose itself near that elbow). Cannot figure out if there is gook in the translucent hose running from pump up to top of machine, nor how to clean it, although a strong flashlight does show some discoloration inside hose when shining it through from outside. I'm assuming there is some gunk in there. Curious if compressed air from a compressor will dislodge gunk, or possibly cause damage to hose.
Saw some posts on other forums, with no answer....if pump is having problems, will that cause the tub to not spin?
Ran through the diagnostic test C:00 - C:08. Don't have a Prewash Option, so used the Rinse/Hold button to advance through steps (Machine will automatically advance through each step even if I don't touch the Rinse/Hold button). First time through the diagnostic, pump started grating at C:06, and continued all the way through to the end. Every step along the way seemed to work properly. But still had sopping clothes in washer, so decided to run diagnostic a second time. At C:06, grating noises began again and tub spun at C:07, but this time, at C:08, tub would not spin at all although pump was still on and making grinding noises. Let it run about a minute, but no spin at all. Then it erroed with a SUD code. When trying to turn machine off during this C:08 step, all controls seemed to be disabled. Had to unplug machine from wall to get it to turn off.
Tomorrow will pull pump out to check impeller, and will bring in a compressed air line from garage to blow out the translucent hose(does this hose go directly to the exhaust elbow on top right rear of unit?). Still unsure if it's solely a pump issue, or if there's a motor(spin) related issue as well. Back to the question of whether the malfunctioning pump will prevent the tub from spinning.
Saw a replacement pump for a very cheap price of $80.00 (others were asking $135.00), but would hate to replace it if this might be a gookus issue or something entirely different.
Sorry for all the words, but trying to give as detailed info as I can :)
Thanks in advance for any guidance!!!!
Andy
  • Andrew Goldfeder
    Andrew Goldfeder May 22, 2009
    Thank you for your assistance!!!
    Went back in and removed the pump and separated the pump impeller/motor assembly from the pump housing. The impeller looks pristine and I found no evidence of anything having ever hit or jammed it.
    When spinning the impeller by hand, it rotated freely about ¾ turns and then felt as if it was pulled to one of the magnets, yet it didn't seem to do this when spun in the other direction. So, I removed the coil assembly from the impeller housing, and found that the impeller did not always move freely without any stiction. It will turn 2 or 3 full revolutions and then bind up slightly, and then spin a few more turns and bind again. It's almost as if there might be something inside free floating around that occasionally gets in the way. So, I'd like to just replace the gray impeller housing/impeller/O-ring. Everything else seems to be OK.
    First, should the impeller when removed from the coil, spin freely with no stiction? Or, does it need the magnetic field to keep it floating centered within the housing? And second, is it possible to just buy the gray impeller housing assembly, without having to purchase the coil and pump housing? I could only find a parts # number callout for the whole thing.
  • Andrew Goldfeder
    Andrew Goldfeder May 23, 2009
    Thank you once again!!! Your help is greatly appreciated!!!
    I ordered the pump assembly from Sear. Now for the long wait (specified as 11 days), and many trips to the laundromat :)
    As to troubleshooting....I was one of those kids who had to take clocks apart to see how they worked. I was fascinated by the gear trains and springs and such. Most of the time I was even able to get them back together and fully functional, although sometimes I would have an "extra" part or two leftover. Nowadays, when thinking back, I'm surprised that my parents didn't lock up the screwdrivers as they did with the alcohol, cigarettes, and toxic under-the-bathroom-sink chemicals. So, with that said, taking things apart to see how they work is standard operating procedure with me. I just wish that when things needed repair, individual parts were available, without needing to purchase whole assemblies. It just kills me to have to purchase housings and bushings, and shrouds and gaskets, etc., when all
    I need is a shaft housing. :)
    Thanks again!!!
    Andy
  • 5,911 Answers
If the drain pump is damaged to the point where it generates an error code, the washer typically will not complete a wash cycle. Although it is normal for the pump to get noisy with age, it should not be excessive.
"F02" is a Long Drain error, usually associated with a pump that is either restricted in its ability to drain, or a pump that is not running properly. The "SUD" error is commonly displayed in conjunction with the the "F02" error code. This is caused by the presence of air in the pump.
It doesn't take much to damage these pumps. The items you found (particularly coins) can cause irreparable damage to the pump motor and/or impeller. The impeller blades commonly get sheared off, or become stripped and will free spin on the motor shaft. The black portion of the pump you mentioned is the motor. The impeller should be located on the inside. You should be able to see it with the access cover on the clean out trap removed.
Another recommendation for clearing the drain lines is to remove the drain hose from the standpipe and pull a vacuum with a wet/dry shop vac. This will pull water from the tub, through the pump, through the lines. If there is a clog anywhere, the vacuum will strain and the drain lines should collapse. If the lines are clear, you more than likely have a bad pump. If the error code will not go away, it is recommended that you replace the pump. If you need instructions, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Searspartsdirect.com carries your pump for about $71. Just type in your model number and look under the "Pump and Motor" heading for item number 10.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: When attempting to clear any error codes on the washer, you need to unplug the unit for AT LEAST 30 minutes.
Posted on May 22, 2009
  • Jeff Rockwell
    Jeff Rockwell May 23, 2009
    I applaud your efforts in troubleshooting, but the only way you can purchase the pump is by buying the whole assembly. I have not ever been able to order just the motor, or individual components. And, to the best of my knowledge, the impeller should free spin with no resistance. The web source I provided to you was the cheapest I was able to find this pump priced.
  • Jeff Rockwell
    Glad I could help you. Unfortunately, in this modern day age of technology many of the component level troubleshooting procedures have gone by the wayside. Manufacturers seem to think its more cost effective to throwaway perfectly good parts in the process of replacing one simple component on the entire assembly. This generates more waste than efficiency in my opinion. I feel the same frustration as you do at times and have never understood why you can't purchase certain parts. Good luck to you.
Had repairman fix my disherwasher few days ago not draining. Now it's noisy while washing which was quiet before
Look around the bottom of the tub for foreign material, like a knife, spoon, nut or bolt.
I think if the repairman had "done it", it would have acted up immediately.
Also, look for anything sticking below the basket that might be interferring with the washer arm that spins around, too.
Jul 20, 2014 | KitchenAid Dishwashers
How do I check the belts or springs holding the washer tub
to check the belt or Air shock , its easy to remove the rear access panel , you can have a look for shock and motor & belt but there are a lot of reason for your complaint for doesn't spin out water and noisy when spinning it may be have kinked in the drain hose or the spin start before pumping water out properly leads to load unevenly distributed in the movement of the drum, so i believe that your problem in pumping the water out. Alaa Refaei
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
It make a whirling sound on the spin cycle
see the causes, and proceed with common sense, God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video.
Motor
You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.
Sep 22, 2012 | LG Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Banging noise when spinning
see the next steps and use the common sense: God bless you
Level
Timer
Transmission
Motor Coupler
Motor
Suspension Rods
Drain Pump
Aug 01, 2012 | Washing Machines
Noisy on spin cycle "rattling"
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Duet Washer - Problems with the Spin Cycle
you might want to call whirlpool cause it might be still in warranty
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Repairing the Water Pump
The error code occurs if the pump does not drain within (I believe) 8 minutes. With the tub empty, you have no resistance from anything to obstruct the flow of water. With the tub full, its going to put a bit more strain on the pump to extract water. If the pump motor or impeller are damaged, it may be just enough to cause the pump to run slow enough while the tub is full and cause the error code. If you have already verified all the drain lines to be clear, and have no drainage issues with your household plumbing, the manufacturer recommends you replace the drain pump.
Go to searspartsdirect.com and type in the model number you provided. The pump will be located under the "Pump and Motor" heading as item number 10 (part #280187). It is only sold as a complete unit.
If you need instructions on how to replace the pump, please read this link:
I hope this helps answer some of your questions/concerns. Let me know if you need further assistance.
Nov 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,461 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
