Question about Arcam Audio Players & Recorders
Arcam alpha 7
Reads disc but not play
  • 31 Answers
SOURCE: arcam alpha 7 amplifier goes back into standby when volume is turned up
Can you, or can someone you know, check for DC voltage on the speaker terminals when the amp is on, but not playing? Ideally, the meter should read 0mV with no signal, and certainly less than +/- 10mV. Anything over +/- 30mV is worth having checked out, especially if it changes as you turn the volume knob with no signal applied.
Posted on Sep 20, 2008
SOURCE: I have recently purchased a arcam alpha 10 amp to
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
Posted on Jun 22, 2009
Grubhead
  • 5158 Answers
SOURCE: arcam alpha 8 amp keeps blowing fuses
When the fuses keep blowing suspect an overload in the power supply or on the Main Power Amp board. Chances are that a semiconductor has developed a short and is acting like it was just a piece of wire. The main suspects are power transistors. These can be tested with an Ohm Meter, even in circuit! For when the test probes are applied to each terminal, the meter will act just like you were touching the probes together.
Posted on Sep 10, 2010
AJIN G
  • 6694 Answers
SOURCE: problem with my alpha arcam 7 amp.. internal 240v
hi,
I have the service manual of ARCAM AVR 200 with me. send me a mail on my mail id. I will send u the service manual. its a large file having a size of 4.8 mb. I can sent it through fixya.
agingopakumar@yahoo.co.in
Check the standby transformer T752 first. if its primary winding is short the this problem can occur.
ok
Posted on Jan 17, 2011
Grubhead
  • 5158 Answers
SOURCE: Arcam Alpha 7 amp. Internal 240v 25A fuse blows
Fuses blow like this due to an overload. The cause being a semi-conductor such as an IC or transistor acting like it was a piece of wire. The most common cause is a shorted output transistor(s) in the main amp. But the power supply can't be ruled out. If you have an ohmmeter then a shorted device will be easy to spot. As it will be just like you have touched the probes together when a part (even in circuit) is tested.
Posted on Jan 18, 2011
Re bad disc message. the disc is stuck inside the unit. Initializes, cannot eject disc, then gives a 'bad disc' message.
Hi. I would contact Arcam directly for this - there may be a reset action you could perform or they could diagnose the fault further.
HTH
http://www.arcam.co.uk/advice/contact.htm
Jul 13, 2016 | Arcam Solo Mini Compact stereo receiver...
Door keeps opening.
Replace the loading tray belt, it is quite a common problem on CD Players using the same Sony transport mechanism as your Arcam.
The belt loses its tension and cannot fully load and then spits the tray open.
When you try to load a CD you should be able to hear a whirring sound after closing the tray and that's the motor trying to lift the laser mechanism at full travel but is unable to hence not enough tension on the belt.
Hope this helps.
Jan 18, 2011 | Arcam Alpha 7SE
Problem with my alpha arcam 7 amp.. internal 240v 25a fuse blows right after switching it on even when all speaker and RCA cables were disconnected.i need the schematic diagram. Where should i start the...
hi,
ok
Jan 17, 2011 | Arcam AVR-200
I am setting up 4 bose 901s to my home stereo and am unsure how to connect my components to tha 901s active equilizer. the 4 901s are connected to 4 marantz ma 500 amplifiers. the amplifiers are...
Hi -
Sony CD player Red / White RCA - > CD input RCAs on the Arcam.
From the Arcam Preamp Output RCA's, go to the Bose "Input". From the Bose "Output", you need RCA splitters to make them into four outputs to run your amplifier connections.clmrt5000_2.jpgclmrt5000_3.jpg
Jan 15, 2011 | Bose 901 VI Main / Stereo Speaker
My cd player stopped working the power light is not showing i have changed the lead to make sure it was not the fuse
Check for bulging / leaky capacitors on the main PCB, they are a common problem on Arcam CD Players.
There should be a few 25v 1000uf caps scattered around, check those first.
Hope this helps.
Dec 04, 2010 | Arcam Alpha 7SE
My CD tray closes before I insert disk
check the micro switches on the cd mechanism. these can go wrong sometimes. it's obviously not sending a message to the micro chip that the tray is open therefor it will close again automatically.
hope this helps?
May 10, 2010 | Arcam Alpha 7SE
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
May 04, 2009 | Audio Players & Recorders
Arcam alpha 7 amplifier goes back into standby when volume is turned up
Aug 29, 2008 | Audio Players & Recorders
18 people viewed this question
Top Arcam Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
berggei
Are you an Arcam Audio Player and Recorder Expert? Answer questions, earn points and help others
