Question about Intel D101GGC Motherboard
My Intel D101GGC Motherboard doesn't power up!
None of the leds light up in the front...
  • 210 Answers
Is it properly plugged in?
is you power supply fan working?
is your power supply working?
do you get any post bleeps?
is your cpu working?
are the leds on the motherboard(physically)or on the external case.if on the case then check the cable on the motherboard
these are some of the questions which will narroway down your problem
Posted on May 22, 2009
E-Machines T3508 PC Desktop Motherboard connecting the wires
The eMachines T3058 Desktop PC uses an Intel D101GGC motherboard.
The plastic front of your computer is the Front Panel.
The rectangular area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Front Panel header:
This link takes you to Intel Support, and the download page for the motherboard manual, for the Intel D101GGC motherboard,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
On this page click on the blue -
Intel Desktop Board D101GGC Product Guide - English (PDF)
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
{ Took 7 seconds to download just now, with no additional download time needed.
Using medium speed DSL connection }
Ignore the following if you are aware;
At the top of the PDF file is the PDF file page number box, and the Zoom Out/Zoom In icons.
Zoom Out ( + ) enlarges the page view, Zoom In ( - ) reduces the page view.
For myself I reduce the view size to 100 or 75 percent.
The page number box is to the right of the Down Arrow.
(If you do not see this, hover your mouse cursor towards the bottom/middle. When the icons come up, {They were 'ghosted out'}, click on the PDF icon to the far right )
Provided that somehow you cannot download this motherboard manual;
Orient the motherboard so we are both looking at it in the same direction.
Same as it sits in the computer case.
Processor to the Top, Ram Memory to the Right, white PCI slots to the bottom.
The Front Panel header is at the Bottom/Right.
It is a rectangular block of plastic with two rows of pins.
4 across the Top, 5 across the Bottom.
It is numbered Even on the top, and Odd on the bottom.
Starting at the LEFT side going towards the right, on the top row;
Pins 2, 4, 6, and 8.
There is no Pin 10, just an empty space.
Starting at the LEFT side going towards the right, on the bottom row;
Pins 1, 3, 5, 7, and 9
A) Pins 1 and 3 are for the HarDDrive activity LED light. (Orange)
Pin 1 is for the Positive wire ( + )
If the LED light is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. (Blue)
C) Pin 9 is for 5 Volts. Not Used (Black)
D) Pins 2 and 4 are for the Power On LED light. (Green)
Pin 2 is for the Positive wire ( + )
If the LED light is dim switch the wires around.
E) Pins 6 and 8 are for the Power On switch. (Red)
Do not know what wires coming from the Front Panel are the Power On switch wires, Power On LED light wires, or Harddrive activity LED light wires?
Remove the Front Panel, trace the wires to the Power On switch. (Two wires. Probably twisted together. Or all wires are in a single sheath)
Same for the Power On LED light, and the Harddrive LED light.
Need to know where the harddrive, or optical drive plugs in?
Need to know where the power cables from the Power Supply plug in?
Please post back in a Comment.
Regards,
joecoolvette
Oct 11, 2011 | E-Machines T2893 PC Desktop
A computer with a D101GGC motherboard does not start. There is no beep or monitor singal. The fan is okay. As soon as the power is connected to the computer, the red drive access light comes on, but not...
its a common problem with intel D101GGC motherboard, just open the case and unplug the dvd power cable and data cable, then turn on the PC it will work fine.
Jan 09, 2011 | Intel D101GGC Motherboard
Need to know which style of m b I have is it an atx
The difference between ATX and MicroATX is the size. An ATX board will usually have 6-7 slots to add cards like video, network or sound cards. An ATX board will also usually not have a video port on the board. A MicroATX board will usually have only 3-4 slots to add cards into it, at least one of which being dedicated to AGP or PCI Express Video cards.
To answer your question: That computer uses a MicroATX board. A Micro ATX board will most likely work in any PC Case whereas an ATX board requires an ATX size case (Mid or Full size Tower).
Jun 06, 2010 | eMachines T3508 PC Desktop
Intel D101GGC Motherboard no power on
Can you see the motherboard led (green/red light inside motherboard when the power switch is on)? If so, clean all the components on the motherboard by removing ram, processor, pci cards, power cables, ide/sata cables etc.. and blow away all the dust, also remove the bios battery and leave it outside at least 5 mins. Reinsert all the components and reboot, if this isn't successful, try changing your ram and power supply.. If i can't be solved after this.. your motherboard might get shorted inside the circuit which we can't fix manually. Good luck...
Apr 18, 2010 | Intel D101GGC Motherboard
Hello i use Motherboard Name Intel D101GGC my
try mic in front panel..to use on back panel, uou have to change option on sound settings near the clock on right-down corner goto>recording>unmute or check rear mic.
thanks
Apr 04, 2009 | Intel D101GGC Motherboard
Display Problem.
Motherboard blown, contact me for support at compdoctor2005@btinternet.com for inexpensive repair options
Nov 26, 2008 | Intel D101GGC Motherboard
Where to plug on/off and resets?
Hi ironjohn20, please open your manual to page 11. Look for the letter "R" which is called, Front Panel Header. This is where you connect the case LEDs to the motherboard. A decription of what goes where at the bottom of page 39.
61279ab.jpg You can download the manual in PDF format directly from Intel by clicking on this link; http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2229&lang=eng
Choose your operating system from the drop down menu & click GO. The manual is located at the bottom of the page, number 8.
Good luck ironjohn20!
If I can help further just ask.
Mike
Sep 01, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard front headphone mic not working becoze wire not attach in motherboard
Simple dear connect the wire on Motherboard. The pins you will get near the outer portion of your motherboard.
Feb 24, 2008 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
111 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
